Question about Lands Phones
Need help with setting up auto dial - Lands Phones
Very dark video output and view through the view screen, no matter where the ISO dial is set. The Auto, C1 and C2 mode for Photos is just as dark. I can take good pictures only in P (Program) mode, al
This is most often a problem with the imaging sensor and no reset is going to repair the part. Also, if replacing it, it needs to be properly calibrated after installed. If you need help with this, this is the place we recommend for the Canons: www.CamerasAndParts.com They are the best for these models, they only work on Canons and they are excellent for repairs. They have a service package for about $90 which takes care of an image problem as you have or you can try emailing them first. As far as service and the quality of work, I wouldn't go anywhere else but them for a Powershot. They are the best for these cameras. Good luck
Dec 20, 2014 | Canon PowerShot G10 Digital Camera
When i calling my mobil atomacally dialing
abdul Rakib, it seems your green button is very sensitive, make sure you are not pressing twice and if problem persist post more comments for further help.
Jul 03, 2012 | Samsung star II duos GT-C6712
How do I set my Canon EOS Rebel T3i 18 MP CMOS Digital SLR to auto mode
If you mean the auto exposure mode, turn the mode dial on the top of the camera to the "A+" position, between the "P" and the lightning bolt.
If you mean autofocus, set the switch on the lens to the AF position if the lens has an autofocus switch. On the camera, press the AF button (cursor-right) then turn the command dial to select the desired mode.
If you mean the auto white balance, press the WB button (cursor-up) then turn the command dial to select the desired mode.
In the auto exposure mode the ISO mode is set to auto, and you can't change this.
If you need a manual, you may download a copy here.
Feb 02, 2012 | Canon Cameras
How do I disable the pop-up flash on Nikon D5000? Thanks
As long as jog dial is set to M or manual, the flash will not pop up automatically. Be reminded though because you have to set everything manually. If you want the auto settings without the flash, set the jog dial to the icon that looks like a lightning with stop/ no sign
Mar 02, 2011 | Nikon D5000 Body Only Digital Camera
When i am attaching hands free the outgoing call is activating automatically what can i do
I have done this on my ittle LG flip; I realized I was inadvertantly pressing the auto-dial while I was inserting the phone into cage & closing gap; had no idea why phone was ringing!!! Check all the buttons on both sides of phone; check what happens when you press each button....OR, go back to your User Manual & be sure you arent in an auto dial mode.
Alternately, you may be hitting a one touch dial; check for this by going into the Menu, then Settings, then something that looks like Dialing Match or Set Speed Dial; if it indicates something similar to ^auto dial last number^ then you can resove this by changing that setting. The best way to play with this & not be calling anyone is to remove your SIM card first (remove battery & slide the little card out); most phones will still power up, they just cannot connect any calls & the SIM has your directory info only, not the phone menu.
All the best, I hope some of this helps, and have a safe, happy holiday season.
Nov 17, 2010 | Cell Phones
My camera has lost the ISO settings... it now only shows Auto and High. Also the flash only shows Auto and On... no other options.
Hi -
When you power up your camera,
dial the top dial to the "P" choice
for programming. You should see an "L" shape
of choices on the display.
Double-click the middle button WITHIN the circle on the back.
That will allow you to scroll through the options, including your ISO, and you can choose what you want.
You can leave the top dial on "P" to use your custom settings,
or go back to "Auto" and see if you get the results
you were wanting.
Hope that helps you!
Oct 31, 2010 | Canon PowerShot A1100 IS Digital Camera
Turning alarm on and off
I'm afraid I don't have a manual, but I could walk you through the steps...
1. Press the clock/sleep/timer button twice.
2. Press enter button.
3. Turn dial to set hour for alarm to start.
4. Press enter button.
5. Turn dial to set minute for alarm to start.
6. Press enter button.
7. Turn dial to set hour for alarm auto-shut off.
8. Press enter button.
9. Turn dial to set minute for alarm auto-shut off.
10. Press enter button.
11. Turn dial to select either Radio or CD alarm setting.
12. Press enter button.
13. Turn dial to adjust volume of alarm.
14. Press enter button.
15. Press standby button. Alarm is set.
I hope this helps! Best of luck finding a manual if you still need one. :)
Jun 03, 2009 | Sony PSYC CFD-E90 Radio/Cassette/CD...
Connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Nov 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Set up auto dial on Bell South telephone 840V
"Store", "Tele NR", "Auto Nr", "Save"
Oct 14, 2007 | Lands Phones
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
