Question about Lands Phones
Trying to program 1 # dial but it won't connect to phone to call
Speed dial does not work
Look at the number that is in there for the person you are trying to speed dial,your voice mail is always #1.To use speed dial you just use the number the person you are trying to speed dial lets say they are in your phone as #2,hold down the # 2 on your keypad for around 3 seconds and it should start dialing.
Jan 01, 2013 | Net10 Motorola W409G Prepaid Camera Phone
Nortel Norstar T7316 programming extention to button. Won't let me program extension 230.
Just think about it, why would you want to auto dial yourself? You don't need an autodial key for yourself so the system don't allow you to program it.
Sep 25, 2017 | NorStar Meridian M7310 Phone
Trying to change my name displayed on the LCD?
It's a trick. When we install Panasonic TDx systems, you have to give the phone users access to programming. If your installer gave you access, you can press PROG and dial **1234 and the system will let you into programming. By default, extension can usually do it, in our case, we allow it on all phones.
If you find the phone that can dial PROG ** (it won't beep at you when you start the sequence), program 004 is extension names. Dial it, press ENTER twice (it moves from softkey 3 to 4) and you'll be looking at extension 101 and a name if programmed. The NEXT key scrolls through the extensions and the keypad pressed X times to get to the letter and the right arrow key to step forward if you need to press the same number key steps you forward. The round ENTER key saves the new name, then pick up the handset and drop it back down to exit programming.
Carl
Jul 01, 2011 | Panasonic KX-T7630 Corded Phone
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
I push the feature button it turns red as soon as i enter the phone number the light goes out press feature and does not program
Why are you pressing the feature button?
Press feature then answer. You envoked ringing line pick up.
Press feature then speed dial button, dial a number like your dialing out, then feature again. You've just set a speed dial button.
Press feature, then 3 and you've changed your ringtone on a series i phone.
Mar 16, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I have a Prostar 816 Plus. I disconnected the power cable today to connect it to a new battery back up surge protector. I then tried to dial out and it sounds like an old rotary phone. It allows me to dial...
To change the dialing from pulse to dtmf dialing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #42 the screen should momentarily say trunk dial typethen display the current programmed data (00000000)
3) enter in 0 for pulse dialing and 1 for dtmf dialing for each of the lines. i.e. touch tone dialing for lines 1-4 would be 11110000. all 8 digits must be entered for the program to accept the data
press # when finished.
Dec 15, 2009 | Samsung Prostar 816 Phone
The deafault password isn't working to change the date and time
Either make sure yuu're trying it from the phone in jack 1, find out who changed it, or try the following:
If you have a TA system, you can program the time from the phone connected to jack 01 (usually ext 101) by pressing PROGRAM 0 and dial YYMMDDwHHMMa STORE where the time is in 12 hour format, the w is day of the week, with Sunday being 0 and a is 0 for AM or 1 for PM.
Carl
Nov 02, 2009 | Panasonic KX-T7731 Corded Phone
Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Carl
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
KX-T7730 phone. Need to reprogram one of the PF buttons as a CO2 button. I accidently messed up the programming of this button while trying to program a different PF button as a one-touch dialing...
Just so we're on the same page, the PF buttons are the 12 buttons on the right and their ONLY function is one-touch dialing. They can't be CO buttons. The 12 buttons on the left are called CO buttons and they can be programmed to do a number of things, including CO, DSS, and feature access buttons.
To reprogram the button, press PROGRAM, the button, the dial 0 + the CO number (1-8) and STORE. Extensions are 1+ext and one-touch are 2+. Other features are in the programming guide.
The PF buttons are programmed by just dialing the digits, but if it calls out, you must dial an access code first, usually "9".
Carl
Jun 17, 2009 | Panasonic KX-T7730 Corded Phone
I have a Norstar M273724, and I am having one HECK of a time trying to program my personal speed dials. Any ideas?
You need to use Feature *1, Then press the button you want to program, dial the number, and press Rls or Release
Jun 11, 2009 | NorStar M7324 Phone
Lands Phones Logo
26 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
