Question about Home
5600 economind water softner, one of the kids moved the program wheel now it seems like it regenerate to often
  • 659 Answers
SOURCE: water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Posted on Mar 31, 2009
ftw1952
  • 10319 Answers
SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Posted on Jan 24, 2010
  • 569 Answers
SOURCE: Water Softener won't regenerate
mmmm.
I see they charge for a user manual!
I am not familiar with this controller. Is there a manual overide - a large screwdriver slot on the frint of the main shaft?
If so, you should try turning that (clockwise) to the next position and see if the moter will drive it from there. If not, then take it right through 360 degrees, one step at a time.
If it does not work on the next cycle then you may have to replace the controller.
Posted on Feb 20, 2010
Testimonial: "Very helpful, and was quick getting me a possible solution!"
  • 15 Answers
SOURCE: when should i manually regenerate
If this unit does not cycle on it's own, you can cycle it manually anytime you won't be using water for about 2 hours, or if it's a time clock, one that has a fixed day schedule, and you have extra guests using water, you can perform a manual cycle to help regain capacity.
Posted on Dec 17, 2010
h2oservices
  • 306 Answers
SOURCE: Fleck 5600 won't begin regeneration
Check to see if it is on proper time of day, if not the timer/drive motor may be bad. If it is a metered system make sure the meter cable is plugged in to meter and in back of timer assembly. Turn the large black knob in front (if mechanical valve) if it turns very hard or does not move the main piston is frozen up and should be replaced.
RJ
Posted on May 08, 2011
Aquafine Sensimatic will generate manually but not automatically
I am not familiar with this brand. If it is not regenerating automatically that usually indicates it is not metering the gallons/usage (there should be flow indicator FLASHING on the control board) or the programming was reset to factory specs causing unit to not regenerate often enough and running out of capacity. If you can post a picture of the unit it will help.
RJ
Nov 21, 2011 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Fleck 5600 will not regenerate automatically. It will regenerate if manually started
Need more info ! Is this a meter control, or day wheel ?
Does the clock keep accurate time?
If you reach around the back of the timer control box, on the left hand side, can you feel heat from the timer motor?..It should feel a bit warm
Dec 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have a fleck 5600 water softener timer (not economider) dont understand the setting of the days of week when there is 12 pointers on the skipper wheel?
The 12 day wheel is used primarily so that the unit does NOT regenerate on the same day of the week, every week.
There is a 7 day wheel available for this valve so if you irrigate on specific days, and you need it to cycle on specific days, you have the ability to do it without the softener cycling at the same time as watering schedule.
Nov 15, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
We hyave a Watco water softener odel 844, we or having a odor problem what does this mean?
if you have a smell like rotten eggs you have a hydrogen sulfide problem which you can treat in two ways you can add on a carbon filter that regenerates with either chlorine recomended or an airator system which you will smell on the side of your house you can have your hydrogen sulfide checked to see how many parts per million yuou have in your water
Sep 14, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How do I increase or decrease regeneration frequency?
Water filters do not have a regeneration cycle, they filter the water as it passes through. You do have to replace the filter and the frequency of doing that depends on the sediment in your water. If you are talking about a water softner which does regenerate, all the new ones have sensors in them and they regenerate only when needed. This saves tons of salt over the old systems you would set to regenerate every two or three days whether they needed it or not.
Sep 10, 2010 | Culligan Sediment Water Filter
How do i increase softness
A water softener ether softens or it doesn't. If you are getting hardness leak through continually check to make sure that the bypass valve is closed completely. ( the handle where the pipes go into and out of the softener, make sure the pointer is pointing to service). If you are getting soft water most of the time and it goes hard just before regeneration check the incoming water hardness, if it has gone up you will need to adjust the hardness setting on the unit or if it operates on time, set it to regenerate more often.
Mar 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
mmmm.
Feb 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Will not stop regenerating water keeps running
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Water softener seems to be draining all the time
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Home Logo
74 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
