X2Gen monitor goes black off and on during use
I have a Dell computer with a flat panel X2Gen monitor and off and on during use the screen will go black like it's gone into sleep mode except in order to get the screen back up on the monitor, I have to shut it off and back on. Sleep mode is not engaged. This has just started happening during the last couple days. I've checked all my connections just to make sure nothing was loose. Possible solutions short of buying a new monitor which I can't afford right now? Thanks for any assistance you can provide.
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service contact us for details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 22, 2009
I have a Dell SE198WFP Flat Panel Monitor, screen goes black?
The LCd panel may be damaged and will cause this problem.
Another thing is overheating of the GPU.
The LCD signal receiver can be goign on you.
The is also the possibility of a faulty inverter.
Only thing to do is service or replace. Test the unit on another computer, if you don't get the issue there then you know its a problem with the PC.
Jun 03, 2010 | Dell SE198WFP LCD Monitor
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
My monitor goes blank after a while,power light still on,why is this & what can I do?
Check connection cable with videocard on your PC, unplug it and carefully plug it in again. (Turn off your monitor during this operation). If monitor goes black after loading OS (like Windows), then your screen resolution higher then monitor can support. Load computer in Safe Mode and lower screen resolution.
Aug 10, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Delll flat screen moniter goes black.
Assuming you are running XP.  Right click on the desktop, select Properties, select the Screen saver tap.
Click on "Power"
See adjust the time out so that it is  "Never"
May 18, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
My monitor screen goes black
The monitor is going bad. Either going to be a bad screen or a bad inverter. Also Since you tried it on another computer and its still giving you the same symptoms, you know the computers are fine. To be sure, try another monitor on your computer and if you get video on the new monitor then thats another way of verifying that the dell monitor is bad.
May 16, 2009 | Dell UltraSharp 2000FP 20.1" Flat Panel...
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Turn on the monitor
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell 1704 FPTt monitor goes black after about 20 min
Go to Start, Control Panel, Power Options and change your monitor setting to never turn off. If you do leave your monitor on all the time then you should set up a screen saver.
Dec 22, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
