Question about Vizio Televison & Video
Vizio TV model E241 A1. TV will turn on with the remote and manually but will not turn off unless you unplug it. The little on light will be on but no picture. Seldom the picture will show.
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: My Vizio TV Screen went black last night. I cannot
The slave inverter problably went out. Good luck finding if it is a 6632L-0471A The same thing happened to me and I can not find one.
Posted on Nov 21, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
How to fix? power on white light on no backlight no video cannot turn power off
most likely the main board, BUT not a guarantee. one of the ways Vizio keeps the cost low is by high integration and low parts count. with minimal daughter boards.
Apr 03, 2016 | Televison & Video
My VIZIO TV will not turn on. Ren=mote batteries check fine.
Hi Ranjana,
To check the remote control, please press any key and see it's led through the camera of your mobile phone. You will see purple light blinking if the remote control is ok. If the remote control turns out to be good, it is the TV which needs attention.
Good Luck
Dec 03, 2015 | Vizio 42 in. LCD TV
Why Vizio E241A1 LED TV will turn on, but no picture or sound. Is this the Power Supply Board or the Main Board?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 19, 2015 | Vizio E-series E241-A1 24" LED TV...
Universal code for vizio E241 i-A1 tv
2038,2047,2037. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
May 17, 2015 | Vizio Televison & Video
I have a Vizio model# E241-A1-A1 with no power.Replaced the power supply board, still no power. Can you help.
Hi Clifford,
Why did you replace the power board? No power in your tv may result due to some other reasons also. Diagnosing a fault in any TV needs a certain amount of knowledge and expertise. Without that you may succeed at times, not always. By the way, do you get red led on plug in?
May 05, 2015 | Vizio Televison & Video
Vizio "Smart" TV not working
If the remote wasn't working you should be able to turn it on with the on button, is there any indicator lamps that light or flash or is it like its unplugged?
Nov 25, 2017 | Vizio xrt112 smart tv Remote control for...
How do I make my remote work? It was working then it stopped. I thought it was the batteries, so I bought new ones but it still wont do anything.
Check the remote control for its infra-red emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 10, 2014 | Vizio XRT010 Remote for E320-A0 E241-A1...
Why does the picture on my Vizio tv (model E241-A1) gets bright then darkens?
Check to see if you have a daylight savings option in your TV's settings. It will adjust the screen automatically according to the light changes in your home if it is enabled.
Sep 14, 2014 | Vizio Televison & Video
Televison & Video Logo
35 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
