input source has to be changed to hmdi1 rather than ATV or DTV .. No channel is involved. The remote control should have an input source button on it to select the type of input port the TV looks at.
Connect the ipad to your computer, open iTunes, once the ipad is recognized by iTunes click on "restore" and follow the instructions to set up the ipad to factory settings. Then you can set up the ipad using your iTunes account.
If it wont connect check the DNS, i had the same problem and i check the DNS and it was on no, that was my problem. go to your DNS in your internett settings, maybe thats the problem.
some just unscrew, others have a set screw which is hard to see sometimes, it would be at the bottom of the knob just look around the bottom rim of the actual knob itself, you will see a small hole, inside that hole will be a set screw that you need a little allen wrench to loosen it,, once you've done that , it should come right off ( depending on the knob, there could be up to 3 of the set screws so look carefully)
If you lower the rear seat there is a **** in the carpet on the left hand side. Put your hand through and pull the red lever all the way down this will disengage the motors and alow you to lower the roof manully. Make sure you don't put the rear seat back up or it will push the leaver back up and you won't be able to move the roof hope this helps.
did u ever tried to connect mobile to ur laptop.?..ur laptop has bluetooth.? just right click on the yellow marked adapter and uninstall that..try to do it again from the acer driver cd which is came with ur laptop...thats all
