Question about Dryers
I purchased a Universal Wall Mount Control to operate a current wireless controlled fan with a hand held remote. Why is the wall mount control not operating fan with fans original receiver?
  • 166 Answers
Depending on the age and brand of the fan it could have dip switches on the receiver, the part of the remote control unit that is either up in the canopy of the fan or it may be built into the fan, and the wall control ie transmitter may not be compatible with it. When replacing a remote control unit it is advisable to replace both since it could be either the receiver or transmitter.
Posted on Jan 03, 2017
How do I program a MinkaAire R211 remote?
How do I program a MinkaAire R211 remote? - Fixya
2 hours ago - I have set the wall mount, hand held R211 remote and the fan receiver to the same frequency. 1 & 2 ON and 3 & 4 OFF. But the remote still wont ...
[PDF]Universal Hand Held Remote System - Minka Group
NOTE: The RC212 Universal Hand Held Remote Control System is equipped with a learning frequency function which has 256 code combinations to prevent ...Missing: r211
Minka Aire Remote Control RCS212 and Wall ... - YouTube
? 0:56
Jun 14, 2013 - Uploaded by Del Mar Fans & Lighting
Del Mar Fans & Lighting's Minka Aire specialist provides tips for using these innovative ceiling fan controls ...
Jan 01, 2016 | Dryers
Minka aire wall control not working
It comes with a hand held remote. Unless you have the compatible wall transmitter, you'll only be able to use the hand-held remote. The switch on the wall has to be on for the remote to work.
Dec 14, 2013 | Minka Concept II Ceiling Fan
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
The hand held divice stopped working and the mounted pad light flashes quickly. The mounted pad does work.
The most likely problem here is that your wall control is bad. I would disconnect the 2 wires going to it and I think you will find your remote works. Replace the wall control.
Sep 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can a remote control be installed on the Huntington III?
Yes you can operate them with two styles of remotes: either the remote wall switch, or a hand held remote. Both require the receiver to be mounted above the top of the fan in the base it is wired to. The receiver has wires on both sides; the one side wires directly to the house wires, and the other goes to the fan and light. They are both sold at Home Depot and Lowes. The ones at Home Depot also include the set made by the fan manufacturer.
Feb 01, 2009 | Hampton Bay 24750 Huntington III Ceiling...
2 remotes
Yes, If the receiver is the same model number one remote will work for both... (im assuming when you state remote you are referring to a hand held remote? or are you referring to a wall mount remote? Each ceiling fan comes with it's own electrical unit... I currently have some Minka concept fans if your interested in purchasing at a very good price or if I can help you out in any other way please feel free to contact me at payitforwardx2 @ GMAIL . COM I will be happy to help you in any way I can.
Jun 24, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
Top Dryers Experts
