Question about PfaFF Sewing Machines
Pfaff 1371 presser foot won't provide enough pressure for sewing; I have to press on it manually and hold it
  • 27 Answers
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
Posted on Jan 14, 2009
  • 35 Answers
SOURCE: Pfaff Creative 1371
I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learn the repair skills!
Good luck.
Posted on Sep 08, 2010
SOURCE: pfaff 1471 foot problem. Foot wont go down all
Try lubricating the pressure foot shaft where it slides up and down (2 Places). To do this you need to remove the left side cover - the flat black screw in the slot under the left side of the carrying handle. Back the screw off slightly and pull off the left side plate. This should allow you to oil the shaft. I use Mobile 1 Synthetic 0W-20 oil. I find it works extremely well, as good or better than sewing machine oil. The problem is caused by the original grease they used when these machines were manufactured. The grease hardens over time (especially if the machine hasn't been used for awhile) and causes the shaft to stick. You might need to use a little penetrating oil initially, especially if the shaft is really stuck. This is a fine machine - good luck... LS.
Posted on Jan 20, 2012
SOURCE: pfaff 1371 hand wheel is frozen and presser foot won't lift up or down
the machine needs to be checked to see what's wrong with it
Posted on Jun 11, 2012
  • 1564 Answers
SOURCE: Please please help me someone, the presser foot of my sewing mashine pfaff 2056 is stopped working. Where can be a problem?
Your cam lever is probably broke. I'm not exactly familiar with your machine but see if you can get into that area to verify. If that is too much of a challenge. Take it in for repair
Posted on Nov 12, 2012
Help! I have a Pfaff Hobbymatic 807 that my mother in law owned. I can not for the life of me find a way to reduce the pressure on the sewing foot. Sewing cotton over fleece
If your machine does not have a pressure regulator (and some machines do not), you can make sewing thicker projects easier by using a walking foot. If you are sewing a quilt (two or more pieces of fabric and batting), a walking foot would be the preferred presser foot. Even reducing the pressure will not be enough.
Oct 21, 2016 | PfaFF Sewing Machines
Pfaff 7550 presser foot will not go all the way down after using darning foot and returning to regular sewing.
By chance, do you still have the darning foot on the machine? If so, it is shorter than a regular foot which allows space to manually maneuver the fabric.
Also check that the presser foot pressure is activated and the feed dogs are in the up position.
Sep 06, 2016 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
Pfaff 1371 hand wheel is frozen and presser foot won't lift up or down
Jun 11, 2012 | PfaFF Sewing Machines
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Pfaff Creative 1371
Good luck.
Feb 21, 2008 | PfaFF Creative 7570
Sewing Machines Logo
41 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
