Question about Cell Phones
I am in settings and can't find the accessibility in order to turn off the talk back setting.
    Sergeant:
  • 246 Answers
Go to settings, it may be under accessability or sounds
Posted on Jan 03, 2017
My phone is stuck in talk back and will not let me do anything. It just keeps telling me what the buttons are for. What do I do?
What type of phone are you using? Do you have suri or voice command. If you do then activate voice control and and say turn off TalkBack. You can also try asking for accessibility settings or vision setting. If you can get to the accessibility settings from there go to vision and then turn off TalkBack.
Mar 04, 2017 | Cell Phones
How to turn off talk back setting
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
See link below
https://support.google.com/accessibility/android/answer/6007123?hl=en
Jan 16, 2017 | HOW Video Game Consoles & Games
I have the zte wrap7 i dont know what i did,but i got this voice telling me everything todo.i have tryeded to go to settings and it will tell me to double tap and i do but it wont let me.
it seems you have enabled a accessibility option called talk back to turn it off go to settings > accessibility and turn talk back off from there
Dec 05, 2016 | ZTE Cell Phones
How can you make it announce a text message
Hi
Maybe try going to your phone settings-
Then choose accessibility-
Next turn on your "TALK BACK" feature if you have one.
In your "TALK BACK" SETTINGS :
Change your volume settings to your preferred level
Probably turn off the sound feedback (it is annoying)
Then turn off the tone/pitch changes when speaking
For privacy you can choose to never speak typed keys on keyboard echo.
Make sure to check the speak caller id box
The main box to check is the speak notifications when screen is off.
(This feature is for the the blind or low-vision users.) I use it, but that is just because I am lazy and I don't want to unlock my phone or stop what I'm doing unless it is important to me at the time.
good luck... :)
May 16, 2016 | Cell Phones
How do i turn off the talk back app?
Try going into settings, then Accessibility, should be an On/Off there. Or go to settings, Apps, all & disable ir force stop the app. I am still learning myself. Good luck.
Dec 23, 2015 | Samsung Cell Phones
How to delete talk on android
It depends on what is talking. The sound, voice, input, or accessibility settings in the main menu, or the settings in whichever app is talking.
Aug 25, 2014 | Cell Phones
Moto X talks to me every time I touch the phone. It tells me what I'm touching and I must double touch to open an app. I don't know what I did to do this; however, I want it turned off.
Sounds like you enabled something in accessibility. Settings > Accessibility. Look for the setting to Disable.
Mark
Motorola Support
Nov 28, 2013 | Motorola Mobility Moto X
I can't acess the web nor get my google or verizon emails or google voice
Have you turned on your data? If you haven't tried this yet you must in order to use web and emails. First, click on the bottom left button with the three lines. A list comes up find settings and press it, another list will come up. Next press wireless & networks, scroll to the bottom and press mobile networks. Once there press data enabled to turn on your data. That should enable you to access web and emails. Another tip, in the settings menu, press accounts & sync then press background data this will help with apps syncing. BE CAUTIOUS WITH THESE SETTINGS!!! I advise you turn them back off when you're done using them because they will use a ton of data if left on a may get you penalized by Straight Talk! THEY WON'T HESITATE TO CUT YOU OFF WITH NO REASON EXCEPT YOU'RE USING MORE DATA THAN EVERYONE ELSE IS!!! Sign out of email, Facebook and anything else that uses data constantly. I hope this is helpful good luck have fun!!!
Feb 22, 2013 | Straight Talk ZTE Merit 990 GSM Android...
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 | Watches
    Dont know how to get my emachine E725/E525 laptop wireless
    WEP is for encrypting your wireless signal so no one has access to it. The router needs the laptop to have the correct WEP key in order for it to connect to the wireless signal. WEP can be turned on or off through the router's software, and somewhere in there you'll also find the key that you need to give to the laptop. It's usually a long annoying number.
    How you access the router depends on what router it is. There is also usually a reset button so you can set the router back to the default settings. For example, if you changed the password for the router when it was originally set up, and now you don't know what it is, the reset button will clear your password and all the other information in it, and set it back to the manufacturer's default password. You might not want to do that if there's other things that you don't know how to set -- for example, you might need to enter some information about connecting to your ISP (depending on what kind of router we're talking about).
    If you have the instructions that came with the router, that would be the best place to start. It will tell you what the default settings are, and how to access the router. There are sometimes blank spaces where you can write down things that you've modified, like the password. If someone else set this up for you, perhaps they filled in the blanks so you can get back into the router.
    I don't know what hardware or software people you've talked to, but it seems that if you can't figure out how to access the router's software, you need to talk to the router people (the manufacturer or perhaps the ISP if you got it from them and it's also your DSL or Cable router) in order to get set up. The people who made the wireless card on the laptop can help you with their product, but they probably aren't going to know a whole lot about the router.
    Aug 12, 2009 | E-Machines M2350 Notebook
    Cell Phones Logo
    26 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
