Question about PfaFF Sewing Machines
Pfaff 1471 presser foot won't go down all the way; i have to press on it manually and hold for enough pressure
  • PfaFF Master
  • 11,462 Answers
Perhaps this will help:
Pfaff 1471 presser foot does not go down
Posted on Jan 03, 2017
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
May 07, 2016 | PfaFF Sewing Machines
Pfaff 1371 pressure foot won't come down on it's own
I just addressed this issue with my 6110. There is a spring in the shaft for the pressure foot. Over time the white grease that lubricates the spring and the plastic piston at the top dried up, gumming up the works. I took it all apart, cleaned out the bad (now hard grease), re-greased and put it all back together. Works like new. I used a lithium grease as it is easy on plastic parts.
Sep 04, 2012 | PfaFF Sewing Machines
I have a pfaff creative 1471 and it seems like the pressure foot, when raised, then lowered, doesn't have the proper down pressure. It sticks in the up position, then when I pull it down, it sorta snaps...
Can't believe no one answered you. I would highly suggest you take it in. From my searching around learning about the Pfaff 1471 I was just given. I found it is a very good machine and well worth spending well up to 500 to keep it in good shape. I just had to cut back on the extra I pay on my car payment just to pay the 150.00 tune up on her (ouch). But she runs like a dream now. The machine is so good I didn't even notice she needed it. What you seem to be saying wrong seem to be the most common thing I have read goes wrong with the 1471. I get there is a spring that gets gummed up. It should be replaced/cleaned and regressed by a pro. If its as common as it sounds shouldn't cost more than what I paid.
Mar 29, 2010 | PfaFF Sewing Machines
Pfaff 1471 foot problem. Foot wont go down all the way, I have to press on it manually and hold with a finger for the foot to stay down for enough pressure to run over the fabric. feed dogs are up. Not...
Try lubricating the pressure foot shaft where it slides up and down (2 Places). To do this you need to remove the left side cover - the flat black screw in the slot under the left side of the carrying handle. Back the screw off slightly and pull off the left side plate. This should allow you to oil the shaft. I use Mobile 1 Synthetic 0W-20 oil. I find it works extremely well, as good or better than sewing machine oil. The problem is caused by the original grease they used when these machines were manufactured. The grease hardens over time (especially if the machine hasn't been used for awhile) and causes the shaft to stick. You might need to use a little penetrating oil initially, especially if the shaft is really stuck. This is a fine machine - good luck... LS.
Dec 10, 2009 | PfaFF Sewing Machines
Fabric does not move forward
Either the presser foot does not have enough pressure on it or it is not lowering all the way to the fabric.
Remove the fabric.lower the presser foot.If the presser foot has no or little pressure look for the pressure regulator on top the machine or on the left side and see if you can make it tighter. Not all machines have this.Look to see if there is space between the foot and the teeth when you turn the handwheel. If there is space then the machine needs an adjustment.
Apr 27, 2009 | PfaFF Hobby 4260
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
Pressure foot problem
hi there not sure if the manual will help but if you go to this link you might find it.
pfaff 7570 manual Google Search
or go to this link might help you to find out why.
pfaff 7570 presser foot wont go down Google Search
Nov 04, 2017 | PfaFF Creative 7570
Sewing Machines Logo
146 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
