Question about Chefmate Kitchen Appliances - Others
My chefmate cake carrier has a broken clip, where can I get a new one?
2 Suggested Answers
lkjhbewsrfvw
SOURCE: I have a Chefmate cupcake carrier. (Holds 24
Yes you can... click here and take a look on amazon: Amazon com cupcake clip. I hope this was helpful. Cheers
Posted on Dec 21, 2014
How do I replace an oven door seal?
Piece of cake. Use pliers and pull on the small metal clips that hold the old seal on the door. Now simply press the clips on the new door seal into the same holes. The ends of the door seal should point to the floor when the door is closed.
Sep 28, 2015 | Kitchen Ranges
Where does battery go in Chefmate 7997 transmitter/receiver
As you're looking at back of unit you'll see the belt clip. Slide clip to the left and battery removal latch will be under that clip.
Aug 25, 2013 | Cars & Trucks
Plenetry gear system is broken in rear axle whats Problem
Remove wheel, remove rear diff cover, remove small bolt that retains spider gear cross shaft in the carrier. Push axle in, remove "c" clip on end of axle and remove axle from housing. Reverse to replace. Only problem you may have is that sometimes small bolt is broken inside carrier. if broken you will need to drill a tiny hole into it and remove with tiny "easy out" or other similar device.
Do not turn carrier when shaft has been removed or spider gears will rotate and fall out!
Sep 12, 2012 | Cars & Trucks
Brake light switch replace
I DID ONE YESTERDAY, NOT A PIECE OF CAKE. THE HARDEST PART IS REMOVING THE RETAINER CLIP FROM THE ROUND PEG TO GET THE SWITCH OUT. THERE IS VERY LIMITED SPACE TO WORK IN. LOOKING AT A NEW SWITCH MAY HELP YOU TO GET THE OLD SWITCH OUT. I USE A TRAILER HITCH HAIRPIN CLIP TO HOLD THE NEW SWITCH IN PLACE. GOOD LUCK. KEEP THE BAND AIDS HANDY.
Jan 23, 2011 | 1997 GMC Sierra
Mom lost paddle to Chefmate TR 7000 bread maker. Need another?
hi you can purchase at the following site
Hope this helps
Pls rate the answer
Kurt
http://breadmakerguru.com
Apr 15, 2009 | Chefmate TR 7000 Bread Maker
Rear axle removal
Feb 24, 2009 | 1999 Chevrolet Blazer
Chefmate Automatic Bread Maker TR 440
I have the manual, found your note because I need a new pan (non-stick surface now sticks). Anyway, I could send you copies if you can't find the manual - for Chefmate TR440, printed 8/95.
Dec 10, 2008 | Chefmate TR 7000 Bread Maker
Fan motor on Carrier gas heater is out, hot/metallic odor.
Piece of cake remove the two screwa and slide it out. On some you can just leave the control board dangling until you get the new one in. I always use a cresent wrench to turn the shaft of the motor after removing the set screw and spraying with wd40, Do not bang on shaft, once you cant get a bit with wrench: shake housing ill motor drops out.
Nov 21, 2008 | Carrier 38CKC036 Air Conditioner
Broken plastic side clip
Hi
My dog ate my clip and I contacted info@babybjorn.co.uk. They quoted £44 inc postage to Sweden to get fixed.
Liz P
Mar 24, 2008 | Baby Bjorn Active Baby Carrier
Kitchen Appliances - Others Logo
60 people viewed this question
Top Chefmate Kitchen Appliances - Others Experts
NOEL
NOEL
Jay Finke
Jay Finke
Are you a Chefmate Kitchen Appliances - Other Expert? Answer questions, earn points and help others
