How installed on my computer - Computers & Internet
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
PLS NEED INSTALL
Important Notes
Computer softwares are the programs that would be integrated ino the computer by a process called installation. Available installation softwares include productivity, multimedia, creativitiy and gaming programs. Computers already have programs installed to perform also known as operating systems softwares. When a computer is turned on, the display systems making possible user experince is the defaul programs. Every additional features is capable of being intergreted in processes discribed. A required program whether in video editing is chosen after observing the already existing programs on the computer. The decsion to integrate an additional software is with consideration of an entire computer compartibilily check.
Computer situations requiring installation
1. The computer default programs are malfunct
a. outdated computer programs request integration improved features to function
b. a damage to the computer default programs requires repairs by installing.
2. The option to integrate a program to a computer device
a. several programs are capable of being integrated
Procedures of -installing softwares
component check requirements check
1. computer compartibility to software programs selections required to be installed
a. A computer capacity to hold additional softwares
b. a computer functionalities, productivity, video multimedia creation, computer gaming
c. the programs functions could determine if additonal component parts have to be acquired to complete the integration experiece
contact technical support
Dec 20, 2010 | Computers & Internet
How to install an wirless adapter to mi desktop
Install a wireless network adapterIn areas that are served by a wireless network, you can connect to a computer network without using a cable, and surf the Internet or connect with other computers. To connect to a wireless network, your computer needs a wireless network adapter.
Many new computers-especially laptops-come with wireless adapters. Before using your computer, check to see if it already has a wireless network adapter.
If your computer doesn't have a wireless network adapter, you can install one.
Install a wireless USB network adapter. Most people prefer this type of adapter for any type of computer, because it's easy to install.
Install a wireless CardBus or CF network adapter. For portable computers, this type of adapter (also called a PCMCIA or PC Card) is easier to travel with than a USB adapter, because it is often smaller and fits securely in the PC Card slot on the side of the computer.
Install a wireless internal network adapter. If you have a desktop computer, you may prefer an internal adapter so that you can use the USB port to connect another accessory.
The type of adapter you install depends on your computer and your level of expertise.
How to determine if you already have a wireless network adapterMany portable computers manufactured after 2000 have wireless networking built in. However, because the antenna is hidden inside the computer, it's not easy to see.
To see which network adapters are currently installed in your computer
1.
Click Start, and then click Control Panel.
69010-click-control-panel.gif 2.
Click Network and Internet Connections.
69010-click-network-and-internet-connections.gif 3.
Under or pick a Control Panel icon, click Network Connections.
69010-click-network-connections.gif 4.
Microsoft Windows XP displays your network adapters. Wireless network adapters are labeled Wireless Network Connection. If an adapter displays a red X, it is disconnected. If the Network Connections window is blank, your computer doesn't yet have a wired or wireless network adapter.
Nov 12, 2010 | Computers & Internet
How we can install hp o/s to hprp2470 model server
if your using a HP computer than you wont be able to install the OS installed on your computer.. HP has a feature that protects the OS being installed on any other computer.. in a way it creates an Image of all the Hardware Devices installed on ur computer thereby restricting u to install it on any other computer.. let me know if i was able to answer ur question or u need some other details.. regards, guru :-p
Feb 18, 2010 | HP Computers & Internet
Can not read disk error
You can't install any hard disk from any computer and install it into your computer and expect it to work unless it came from the same model computer with the same devices that are installed on your computer.
When Windows is installed it configures the operating system unique to that computer and stores this info in the Windows registry.
To get a used hard disk to work in your computer, you have to install Windows as a fresh installation on your computer.
May 16, 2009 | Gateway Solo 1450 Notebook
Drive tools software
driver detective
i have used it on multiple pc's
please don't forget to rate
Feb 13, 2009 | Toshiba Satellite A15-S127 Notebook
Driver will not install on Windows XP
BETTER TO UNINSTALL FIRST THE PREVIOUS DRIVER INSTALLED ON YOUR PC. THEN INSTALL AGAIN THE DRIVER
Dec 27, 2008 | Vivitar MAGNACAM Binocular
SOUND ON MY COMPUTER
Hello1
please tell me the model of your computer, so that i can find driver for that device.
However, if you have CD/DVD utilities enclosed in the computer from the vendor then install that utilities. you should install the chipset, VGA, audio and other necessary drivers. (please install that in series to avoid errors on the computer.
best regards, melnavz
Mar 05, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
