Question about NetGear Computers & Internet
Router label for Netgear r6250 does not contain PIN. where else can i locate it? No longer have box or inserts
  • 30 Answers
Press the wps button and will come up to pair
Posted on Jan 03, 2017
  • bob tench Jan 03, 2017
    Continuing with the issue: Thanks - I had a few identical replies. This gets me half way there because when I press the WPS button on the router - where specifically does the PIN display? It does not display anywhere on the front of the router. Thanks for the follow up.
There is no "pin" for this router. Instead, you need to connect to it via a wired connection from your computer and bring up a browser. Enter http://routerlogin.net in the address bar. The default user name is admin and the default password is password.
If you changed the defaults (which you should have done) there is a small hole in the back for a reset. This will remove any customization you have made and reset the router to the factory defaults. Then you can log in and set it back to whatever you had before.
Jan 03, 2017 | Cell Phones
Should be a sticker on the router or the box it came in.
Jun 23, 2014 | NetGear Computers & Internet
How to setup netgear wndr 3400 wireless router
The Netgear WNDR 3400 wireless router configuration process is quite easy. Before you start installing and setting up the router, you should first check the packaging contents. Also, try to become familiar with the router's front and back panels, the LEDs and the necessary details on the router label. If you still experience any problem during the setup process, you can contact the technicians. More information, visit -Netgear Customer Service Technical Support Number USA 2017
Apr 29, 2014 | NetGear WGR614 Wireless Router
My wireless card Marvell 802.11g can see my NETGEAR 6250 but cannot connet to it
Then the settings on the XP are wrong. Check the protocol used (WEP) is on the router. XP probably cannot do WA.
Jan 04, 2014 | NetGear R6250 Wireless AC Dual Band...
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
I DONT KNOW HOW TO PUT MY NETGEAR ROUTER THROUGH MY LAPTOP , SO I CAN HAVE WIRELESS INTERNET ACCESS
u will need RJ45 CABLE (normal ethernet cable, labelled cat5e)
plug one end into laptop network connection other into laptop
login address will be (netgear) details will be under router
http://192.168.1.1pi
or something like that.
login id: admin
password: password
if u cant login then, press reset button back of wireless router, will need to do that with pen or pin?
once logged into the router, use the setup wizard and the the rest is self explanatory.
once setup is dne, with SSID and password, then plug the cable from laptop, in back of the internet modem coming into ur house from ur supplier....and ur ready to surf the web.
find your new wireless network using the laptop and insert the password....
Oct 10, 2010 | NetGear WGR614 Wireless Router
I have forgotten my Password for wireless conection. How do I find it?
Just reset your router and use (admin) for user name and password. To reset your router you can see a small hole in your router which is labeled reset. Use a pin and insert it to the hole and push.
Jun 02, 2010 | NetGear DG834G Router
Forgot my password to allow other devices to access my network.
May 31, 2010 | NetGear RangeMax WPN824 Wireless Router...
How to reboot my netgear router
To reset your wireless router or router you have to insert a pin on the hole "reset" located at the back of your unit during a couple of minutes.
Have a great day!
Pablo :-)
Oct 20, 2008 | Computers & Internet
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
