How do you install a new paper roll in an Ativa AT-P500 calculator? We fed through the bottom back but can't can't find where to feed from there!!
2 Suggested Answers
SOURCE: Ativa AT-P500 calculator; how do I put feed paper
I have the same problem (no manual) but solved it: the port of entry for the paper feed in located on the back, near the bottom. The top piece (where you tear the paper off) moves slightly to the back and can be removed. Feed the paper into the machine; pull out a few inches asnd cut the edges of the paper, about two inches back, into a "V" and feed this point into the slot just below the "ridge" and press "feed". Problem solved!
Posted on Sep 28, 2012
How do I load paper?
I have a casion hr-100tm calculator and found the easy way to load a new roll of paper. Take a 3x5 index card and cut it on 45 degree angle, then with angle on the right of the machine feet it into the machine pushing it as you go. Once it begins to feed so you can pull on it, then take other end of card, scotch tape to new roll of adding machine tape. As you feed the card through the roll of paper foillows. Once it has fed into machine cut off 3 x5 card. Easy.
The problem is that all rolls of machine paper are not equal and the thinner paper doesn't want to feed. This way it works for any type. Hope it hellps.
Oct 02, 2015 | Casio FR-2650A Calculator
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    Trying to replace the paper roll on a sharp EL1801V
    1 Turn off the Sharp EL-1801V.
    Ativa AT-P500 calculator; how do I put feed paper into it? Is there a manual for this?
    May 16, 2010 | Office Equipment & Supplies
    How do I install adding machine paper roll
    Slide off the upper cover of the calculator, and cut across the paper roll to form a clean end.
    If you are mounting the roll externally (outside of the back of the calculator), then look for a slot in the rear of the calculator, which will accept the paper. Feed the end of the paper through the rear slot, and then into the internal feed slot, and hold the [FEED] key. After that, you can flip the arm back to mount the roll and replace the upper cover.
    If you want to place the roll inside of the calculator, then you need to feed from the bottom of the roll into the internal feed slot, and hold the [FEED] key. After you are finished, replace the upper cover.
    Nov 23, 2009 | Canon P1-DHV Calculator
    Cannot load new paper roll into the calculator so it catches
    Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
    When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
    To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
    Then, slide the paper roll onto the feeder arm and you're in business.
    Apr 09, 2009 | Sharp EL-1801C Calculator
    Adding paper
    There is no manual available for this model online.
    However, there are two basic methods. Always make sure you are puting in paper that has been cut cleanly with scissors, not torn, as this can ruin your printer. If you have a slot on the back of the machine, just under where the paper roller typically sits on the holder, with the calculator off feed the paper in that slot (rolling out from the bottom). Then turn the printer on, and hit the feed to advance the paper into the printer.
    If there is no slot on the back, you will see that the opening where the paper comes out from the top is "subdivided", and when it has printed, it is coming out of the front partition of that slot. Make sure the printer is off, feed the paper into the back portion of the opening, rolling from the top. Then turn the printer on, and hit the feed to advance the paper into the printer.
    Either method should solve the issue exactly, and once the paper has fed in, then place the roll onto the holder. You're set!
    Please post back if you need more help, otherwise thank you for using and rating FixYa!
    Jun 07, 2008 | Canon P23-DHV Calculator
    Ribbon installation
    I searched this online, and have found the following instructions:
    1) Set the power switch to OFF
    2) Remove the printer cover
    3) Remove the ink roller by turning it counterclockwise and pulling it upward.
    4) Install the correct color new ink roller and press it in the correct position. Make sure that the ink roller is securely in place.
    5) Put back the printer cover.
    May 30, 2008 | Sharp EL-1801P Calculator
    Register tape
    Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
    First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
    Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle. Looks like >
    Then, place the paper into the slot where the paper feeds into in the back. (Paper will get fed under the printer assembly) and then hit the PAPER FEED/ADVANCE button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
    Hope this helps.
    Have a good day.
    M =)
    Feb 13, 2008 | Sharp EL-2192Rll Calculator
    Where do i put the paper into to replace a new roll
    There should be a small slot towards the back. The paper gets fed from the back bottom, and it comes through the top just behind the display.
    IF you take your roll of paper, tear off a fresh new edge, make an arrow point at the end (fold 1 side to the middle, and then fold the other side to the middle to meet the other side) to make the paper look like : " > " then insert the pointed side in the slot, and then press PAPER FEED at the same time. The paper should start feeding and you should be good to go.
    Feb 04, 2008 | Sharp EL-1701C Calculator
    k24674
    jasbo
    jasbo
