Question about Nikon Cameras
Nikon S33 waterproof firmware 1.1 camera keeps resetting the 13 megapixels settings to 2 mp randomly - when in the middle of using w/o my intervention, how do always use the 13 mp quality setting.
  • 246 Answers
You have to go to settings and allow it. it may be due to other settings enables like zoom, brightness, flash and etc
Posted on Jan 03, 2017
Testimonial: "Why Would "Zoon, Flash or Brightness" change the setting to shoot in 13 MP ?, I set the camera to 13 then take a few pics and come back and it says 2 mp and DOES NOT allow me to set it to 13 again until I fool around with settings, turn on and off or so something then the option seems to come back, I do not have a SURE way setting to make it come back ALL the time."
The 2V9WP BL Megapixel Duo2 waterproof coleman camera keeps resetting the date and time back to January 2015. Can you advise on how to get this set so that it will hold the proper date and time?
I would imagine that this information is available within the manual. If you are following the steps outlined in that, but the problem persists, return it to the vendor.
Sep 13, 2016 | Coleman 2V9WP-BL 20.0 Megapixel Duo2...
I choose the wrong laungage on my nikon coolpix s33 how do I fix n it?
Go to set up menu. It's the last menu item to the right. Choose Reset. You might need to to Google translate if you cannot figure out what the words are.
Jun 05, 2016 | Nikon Cameras
How do i reset shutter count on nikon D610
You can't reset it. It is like your car's odometer. It is factory set to zero on new cameras and it cannot be reset by the user. This is to prevent unscrupulous sellers of used cameras from passing off worn out equipment as newer.
May 31, 2014 | Nikon D610 24.3-Megapixel DSLR Camera with...
I'm convinced you already did read the user manual. There are three things you can reset:
1. User settings. In menu mode P, you can undo all the settings you made. Page 69.
2. Reset all settings. Page 151 Menu settings, chose the wrench symbol and chose reset all. All settings will be restored to factory settings.
3. Reset file numbering. Page 154 Menu settings, chose the wrench symbol and chose reset file numbering.
In the same menu is also the view firmware version. Yours should read Coolpix P90 Ver.X.X .
The latest update of firmware for the P90 is 1.1 Great chance your camera came with that revision already. If you registered your camera with Nikon, they will inform you when a new firmware is released.
Really, there is nothing more you can reset on the camera.
So if something is wrong, it can't be helped with the reset you have in mind, because that reset does not exist.
If you want the firmware 1.1, goto Nikon USA and support. Everything you want is there.
Nov 29, 2013 | Nikon COOLPIX P90 Digital Camera
Nikon coolpix s4300 date and time problem
the default time is set to military. in the setup menu find the default settings and change the time setting.
Mar 25, 2013 | Nikon Coolpix S4300 16.0-Megapixel Digital...
Today I found a firmware update v102 for the EX-S200 Silver model. I want to update this firmware as the color of the picture taken is extremely bad compared to a 3 year old Nikon 10 megapixel. My less...
I doubt this will take care of the problem. The root directory of the drive is the removeable sd card from the camera and it is above the level of the BIN folder. You then plug the sd card back in the camera and hold down the set button. The whole process is outlined
Mar 01, 2017 | Cameras
How do I change the mp settings to 2 mp on a nikon 2200
From AUTO mode, press the Menu button to enter the shooting menu. The first item on it is Image mode. Highlight that, and you will be presented with your choices. Two of them are labeled 2M (1600) for 2 megapixels (1600x1200). The one with the asterisk compresses less, taking up more memory space.
This is all in the manual under "The Shooting Menu." If you don't have a manual, you can download one from the manufacturer's web site at
Jan 25, 2010 | Nikon Coolpix 2200 Digital Camera
Hi! just want to know if it is possible to change the sensor of a nikon D2H by the sensorof the nikon D2X to obtain 12.5 megapixels or more since i love my camera and can't afford to buy a new model my...
In short, no.
The two cameras may look similar and operate in a similar fashion, but your camera uses a 23.3mm x 15.5mm JFET sensor and the D2X uses a marginally larger 23.7mm x 15.7mm CMOS sensor, although both are considered to be APS-C sized sensors. The two technologies are incompatible. All of the image processing hardware is different as well.
If your camera works well then there's no need to upgrade anyway: four megapixels is more than sufficient for prints above A4 size and the sensor produces very little noise. Nobody other than professionals shooting for billboards needs 12.5MP and as higher MP counts = more noise, no professional would use C-size sensor anyway for that level of enlargement. The only advantage you'll gain with more MP is that you can crop the image down more and still retain acceptable quality, but to properly benefit from this you need to be using professional grade lenses and shooting on a rock solid tripod. The only reason that manufacturers produce ridiculously high MP count sensors is that the general buying public automatically think more = better.
If you love your camera then continue to use it: it was built to a very high standard and if serviced every now and then will continue to produce great images with little apparent noise even at higher ISO settings. The best way to invest in better photos is to improve your technique and also to use a good tripod or monopod whenever possible. Upgrade your lenses to the best ones which you can afford and you'll find that the will serve well on the next Nikon which you eventually buy.
Don't believe the hype: you have a great camera. Four megapixels on a C sized sensor will easily outperform more than double that number on a smaller sensor camera and will be less noisy than anything with more megapixels.
Nov 08, 2009 | Nikon D2H Set Digital Camera
Nikon S210- Coolpix 8.0-Megapixel Digital Camera - I want to buy this model...please can you help me out to buy it.
I would recommend you to buy Nikon Coolpix S4000 Nikon's Coolpix S4000 creates touching memories by combining 12.0 effective megapixels, 4x wide-angle Zoom-Nikkor glass lens and an amazing 3.0-inch High Resolution HVGA (460k-dot) touch-panel LCD with sensitive touch. The Coolpix S4000 also features HD (720p) movies for high quality movie recording. The Coolpix S4000, with Nikon's EXPEED image processing concept, 4-way VR Image Stabilization System and Smart Portrait System enables you to get incredible pictures, incredibly easy. Nikon's Scene Auto Selector automatically analyses the scene you are taking and adjusts the scene mode for you. All you have to do is compose, then touchYou can check out more detailed review for Nikon Coolpix S4000.
Sep 29, 2009 | Nikon Coolpix 8.0-Megapixel Digital Camera...
Cameras Logo
42 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
