Question about RCA Computers & Internet
Connecting my Ethernet with my RCA - RCA Computers & Internet
  • RCA Master
  • 3,497 Answers
Get a network switch
and plug modem into switch port and pc's into other switch ports .
Posted on Jan 03, 2017
When I connect my modem to my laptop, all the lights come on except the pc link light. I have already unplugged it and reset it and it still doesn't work. What more can I do?
If the ONLY light not illuminated is your PC link light then that generally indicates a physical disconnect between the modem and the laptop. If you can get the PC link light to light up when connecting to any other device (computer, router, anything), then you are most likely looking at the ethernet jack on the laptop being burnt out. Otherwise, try swapping the ethernet cord. If a different ethernet cord does not resolve the issue and the PC link light does not come on no matter what the modem is plugged into, you are looking at a faulty ethernet jack on the modem.
Aug 17, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I dont know how to connect a belkin wireless router to thr rca modern router?
You will need 2 ethernet cable to set it up Tha first one will go from the ethernet port in your cable modem to the ethernet port of the router mentionned Modem. The next cable will go fron one of the port of the router to the ethernet port of your Computer,
This second cable is placed temporarely to be able to do set the routers settings,
After this is done insert the Cd that came with your Belkin router and it should guide you through the different setting pages of the router.
Jul 25, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have the DCM425 RCA Modem and I'd like to use it with another internet provider but I don't know how to get it connected. Can you help?
Hi.
You should have no problem using the modem with another internet provider as the modem is a cable modem and not a ADSL modem.
Make sure that your new ISP (internet service provider) is supplied by a cable company and not one that comes through the telephone line as the modem will not work if that is the case.
Once you have cable installed its as simple as connecting all the leads like the coaxial lead and the Ethernet lead. turn it on and you should be good to go after about 2 minutes.
Click on the link below for an on-line PDF operators manual for the RCA modem which will tell you exactly how to install the modem.
http://www.simplehelp.net/images/cable_modems/manuals/RCA_DCM425.pdf
Regards.
May 03, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
How can router, cable modem & Vonage modem be connected
Connect the Cable Modem - > The Vonage
Then Connect the Vonage -> The Yellow or Green Slot of the router
Connect your computer -> The Grey slot in the router
Run the Setup
Dec 11, 2010 | Belkin (F5D7231-4) Wireless Router
Can i hook up 2 computers to the rca dcm425 without a wireless router
RCA DCM425 digital cable modems only have one Ethernet cable located in the back of the device. In order to have two computers connected at the same time you will need to have router. The router will connect to the Ethernet port on the back of the RCA modem and then you can have up to 4 computers connected directly to the router using Ethernet cables. If any of your computers are wifi compatible they will also be able to get online by using the wifi from the router.
Sep 29, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Only internet light is blinking
According to the user guide, the modem is trying to connect to the isp. If it is continually blinking, check all your cables. Once you are satisfied all cables are properly connect contact the isp to find out if there is an outage in your area and if not they can help you.
May 25, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a rca dcm315 cable modem a I can connect to the internet through a usb cable but not a ethernet cable. All I'm tring to do is hook up 2 computers to the internet and I just can't seem to get the...
When switching from USB to Ethernet (Or opposite) you have to unplug it, then hook up the Ethernet cable and plug it back in.
Please gave a vote (Rate our solution), it will give me some satisfaction to know that am helping some one so I will keep on helping.
Thank you.
Apr 01, 2010 | RCA Cable Modem DCM315R (11603540)
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Computers & Internet Logo
78 people viewed this question
Top RCA Computers & Internet Experts
Julie Endres
george  peters
george peters
Are you a RCA Computer and Internet Expert? Answer questions, earn points and help others
