Question about Apple iPad Tablets & eReaders
I have a new i pad and cant connect it to my router it wont accept the password
    Sergeant:
  • 246 Answers
Check the capslock
Apple mini I pad
Reset your password. If you make a new account and password you will loose all of your old information, apps and app store purchases.
Dec 12, 2017 | Apple Tablets & eReaders
My kindle cant connect to internet
Go to the Settings Menu, Select the Wireless & VPN option and see if you are in Airplane mode, if you are turn that off. Then select Wi-Fi. See if Wi-Fi is turned on. If it's not turn it on. There should be a list of available Wi-Fi routers. If one is not selected select one that is open or that you have the password to. If none are open or they are locked and you don't have a password, you'll need to get a password for one, or install your own Wi-Fi router.
Jan 13, 2016 | Amazon Kindle Fire HD
Kindle won't accept the Netgear13 password (password) to set-up Wi-Fi.
Is the password case sensitive? If your are 100% sure that you entered the correct password then try lowering the security level of the netgear router temporarily and try again. I have had problems with some devices connecting to higher security levels of wireless routers. Once the device is connected then switch the level back up. However please confirm security level compatibility. If all else fails then use the WPS to connect.
Dec 13, 2015 | Amazon Kindle Paperwhite
My tablet does not connect to Wi-Fi, it says authentication problem, any ideas?
Authentication problem means that the WIFI router isn't accepting the security password that you are attempting to use. They are case sensitive and must be entered correctly or else the unit will refuse connection. The router may also have your MAC address blocked as this is another security option that can be entered by the router's administrator.
Jun 18, 2015 | Tablets & eReaders
NBN was connected yesterday but cant figure out how to input the new security code on my iPad. The new mini iPad connected without hassle and so did the PC. The iPad doesn't ask for the security code it...
This may fix your problem... Clear the cache that is stored in the settings.go to general settings ...look for safari ....empty browser history and cache.
then scan for any networks on the wifi settings....when you get to your router....don't enter password or try to connect to it....click right chevron to get to page that says forget network ....then rescan .....this time enter your password....it should connect.....Apple products are not happy if you change or update passwords on routers already configured.
Mar 02, 2015 | Apple iPad 2 Wifi 16GB
It keeps showing incorrect password,but it works on the other tablet
I don't know what you are being told, but getting rude with us will not get you the help you wish for. If everything were working as YOU state, then there should not be a problem in the first place. However, there apparently IS a problem, and assuming it is not "operator error" (meaning YOU), then we will make suggestions that you can check on and try to get past this problem. It IS possible that the tablet itself is defective and won't connect whatever you try. But since it SEEMS to be making the effort, I would sort of lean in another direction. While it may seem that the password is the problem, occasionally, it is the router, or better stated, the router configuration, that is to blame. Does your router (the one you are trying to connect to) use MAC filtering? If so, the MAC address of the tablet would need to be entered into the table in the router before the router will accept the connection form the tablet. Without that, it would appear to simply be an incorrect password entry as you describe. If that is not the case, then be sure you are attempting to connect using the proper form of encryption on the tablet. Many older units use the old WEP encryption, which most routers do not acknowledge any longer. Ensure you are using WPA or WPA2, whichever the router is set up for.
Feb 09, 2015 | Tablets & eReaders
I cant hook up too wifi i forgot my netgear password help
Go into the manual, and reset your net gear router. There is a procedure for (almost) every router, to reset it. Then you can reinstall the new security with a new password. You don't need a password, because it is an hardware action of something. Be aware all things that were connected, have to be connected again with the new settings.
Jul 02, 2014 | Apple iPad Mini
Wifi connecting
When creating a connection to internet, you need a point (read : router) which facilitates this. If you don't have a router in your neighbourhood, you can't connect to the internet. Even if there is one near you, you must be able to see it, by checking at your tablet for wireless connections. However, some routers are set to accept only connections, when a user ( your tablet) can provide this password everytime it tries to connect to the internet.
Schematic of internetconnection :
Tablet --- WiFi Router --- Modem --- Internet(provider).
Oct 18, 2013 | Velocity Micro Cruz Reader R101 Tablet PC
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
Cant get WiFi conection keeps asking for password cannot remember it
Try resetting the router back to factory default, and set up again with a new password. What make and model of router are you using? Just ran into this issue with neighbors 2 new Kindles, which connect fine to my NetGear router, but will not connect to their Linksys WRT54GS router.
Dec 28, 2010 | Amazon Kindle Wireless Reading Device
Tablets & eReaders Logo
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
