Question about Maytag Washing Machines
Pump access maytag 2400 - Maytag Washing Machines
How to replace a washer drain pump on a MAVT634Aww Maytag washer.Thanks
It's a fairly simple job. Unplug machine. Lean back on back legs so you can access bottom / underneath machine. Remove belt. Place machine back on all 4 feet. Remove access Panel on back of machine in order to access Pump which is in bottom floor of machine. Remove 2 hoses from pump. There will be water that escapes so have several thick towels to soak up water. Pump is held on by 3 self tapping screws. Remove those, and pump will lift right out. Place new Pump in, reinstall screws and hoses. Reinstall back Panel then reinstall belt. You may want to leave back Panel off until you inspect for hose leaks. Don't forget to plug machine back in.
Sep 06, 2017 | Maytag Washing Machines
How to access drain pump on maytag neptune FAV6800 top loader washer
The drain pump can be accessed by removing the rear panel and following the hose down
Jan 26, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Maytag model 2400 stack dryer has error code 3e motor hums but wont spin the tub to dry clothes-also an electrical smell like burned motor windings
Either the motor has gone out, the transmission has locked up or if it is a direct drive system there could be something in the pump that is binding the motor preventing it from turning therefore causing it to over heat giving you the electrical smell.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 04, 2012 | Maytag Dryers
Where and how do we clean Maytag RSW 2400 coils? Do not see them. Thank you. Charles Vallandingham
Hello Charles,
To clean that coil which is located in the rear of the unit behind the cardoard access panel,carefully pull the ref.out and remove the access panel using a 1/4" nutdriver or socket wrench,then you will see the coils to the right side of the compresser(in will be painted black and spiral) use a ref.coil brush that can be purchased at home depot,lowe's of any hardware store and remove all dust from the coil and also the fan motor and fan blade(unplug the unit while doing this) Once done be sure to reinstall the cardboard cover since it is very important to the operation of the refrigerator
The coil should be cleaned two times a year
Jul 23, 2011 | Maytag MSD2732GR Side by Side Refrigerator
Lost the manual for my maytag performa washer A206. How do I access the drive and pump belts ?
The A206 is an old style washer. They are accessed by tipping the machine back against the wall. They are easilty replaced, come as a set...replace them both!
Kelly
Mar 22, 2011 | Maytag Washing Machines
Maytag MAV4755AWW. Water remains in clothes after spin cycle.
Check the drain hose for kinks and clear it from any clogging. If no clogging or kink is found, drain the water manually.
Remove the rear access panel to access the drain pump. Press the hose clamps and move it away from the pump. Remove the hoses from the pump and drain the remaining water from the tub drain hose into a shallow pan.
Lay the machine on its side on a cushioned surface to allow easy access and removal of the drive belt.
Remove the three screws securing the drain pump to the base of the machine. Check the pump impeller for any damage and clear it from any debris that may be preventing it to pump the water out. Replace the drain pump (part #35-6780) if the impeller is damaged. Secure the new drain pump to the base of the machine with the three screws and reinstall the drive belt and the rear access panel.
Note: Disconnect the machine from the power outlet before servicing to avoid the hazard of electric shock.
Feb 22, 2010 | Maytag MAV4755A Top Load Washer
How can we troubleshhot a Maytag toploader that
You probably have something stuck in the drain pump. You will have to remove the hoses from the pump to extract it.
I can not be more help without a model number. Maytag builds several styles of top load washers. They all access differently.
Aug 30, 2009 | Maytag Washing Machines
Maytag washer door stuck locked. Will not open.
access to pump through the back of machine if water in the machine it locks up after 3 attempts to pump out clear the pump by taking the hoses off and yes you will need lots of towels hopefully if you clear the pump reassemble thats the repair done door opens after water pumps out always unplug the machine first
Jun 12, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
