Question about Samsung Dryers
Samsung dryer DV42h5000ew won't power up - Samsung Dryers
  • Samsung Master
  • 5,323 Answers
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Posted on Jan 04, 2017
Samsung dryer won' shut off dv520aep/xaa
If it's in the timed cycle, the timer motor is probably bad, preventing the timer from advancing through the cycle.
If it's in the auto dry cycle, the moisture sensor could be bad, so the dryer thinks the load is still wet.
Mar 07, 2017 | Samsung Dryers
Dryer comes on but won't start any cycle. What could be causing this?
Samsung Dryer Won't Start - Model DV448AGPXAA - Repair ...
www.repairclinic.com/...Dryer/...-/Samsung-Dryer-won-t-start-DV448A...
Samsung dryer won't start? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Dryer Won't Start - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/How-To...Dryer/...---/Dryer-won-t-sta...
If the dryer hums but does not start, the start switch is not at fault. If the dryer does not respond or make any noise, the start switch could be at fault. Use a ...
Troubleshooting Why Your Dryer Won't Start ' PartSelect ...
? 4:47
Oct 14, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer might not be starting. ... If it makes noise but won't start trying spinning the drum empty ten times then close door and try it. ... I changed the door switch and still gives code AU. any suggestions .... thermal fuse everything seems good except my dryer won't come on!!!.
Samsung Dryer DV431AEP - won't start cycle - Appliance Repai
Jan 10, 2016 | Samsung Dv410aew 7.4 Cuft 11-cycle Steam...
Samsung dv219AE drum won't turn
sounds like your drive belt has broken, you may be able to access that from the back, taking cover off, (after you unplug it of course)
Mar 09, 2013 | Samsung Dryers
Samsung DV338aew does not get hot
I just took the front panel off of my Samsung dryer the belt is off. If you take the front panel off you won't believe what you will see it's so much dust... from all the clothes drying. Did you tried to take the front panel off? First turn off the switch to the dryer at the fuse box so there will be no power in there while you vacuum it out. As soon as I can put the belt on I will vacuum it thoroughly. I'm sure that is the reason why it the temp... is not hot enough.
Good luck.
Erika
Aug 12, 2012 | Samsung DV218AEW Electric Dryer
My dryer stopped spinning and it won't heat. it just makes a click sound inside the dryer.
Dear Sir:
See this possibles causes:
Power from the house
Test the main cables from your house, and the dryer for continuity see the diagram attached
Heating element
one heatings elements burn or open, test for continuity.
Thermal fuse
test the fuse for faulty or open, continuity and replace it
Wiring
test for wires burn or break, see for continuity.
God bless you
5_24_2012_10_33_43_am.gif5_24_2012_10_33_58_am.gif5_24_2012_10_34_21_am.gif5_24_2012_10_35_06_am.gif5_24_2012_10_35_28_am.gif
May 24, 2012 | Samsung Dryers
Have a Samsung gas dryer, power comes on and panel lights up. push start button and lights come on but nothing happens, dryer won't start???
What is the model number for the samsung dryer? Usually when this happens there are small thermistors that act as safety devices in the dryer that will prevent the unit from running. For example there is a hi and low limit thermistor that if either will faulty the unit would not run at all the lights would come on but the unit would not run to prevent the unit from getting to hot. Message me back your model number and I will find your schematic showing the thermistors in your unit. You would have to check these thermistors with a multimeter and perform continutity tests on them to assure that they are functioning properly. I await your reply Thanks Rick
Jul 04, 2011 | Samsung Dryers
Dryers Logo
150 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
