Question about LG Dishwashers
LG dishwasher LDF9810ST. After starting it stopped in mid cycle and the display will not show anything or even light up. The interior light works and has power. But controls will do nothing
    Novelist:
  • 112 Answers
First check to see if there is a reset. This is usually some combination of the keys on the display. Your user manual will give you the combination to use.
Posted on Jan 03, 2017
Zanussi tempoline not working, son twisted nob mid cycle it then stopped and wouldn't drain. Now not doing anything! Any ideas? I assume its a error code flashing up
The first step of a dishwasher is a drain / rinse drain. I would turn the dishwasher off at the socket, turn the nob to the off position only turn this in a clock wise direction IE: the direction the nob would naturally move. Turn on back at the wall and start as you would normally. The dishwasher will empty the water out in its first step then should cycle through as normal.
Feb 08, 2013 | Dishwashers
There is a 'Cr' message on the display panel, and none of the buttons respond while this message is displayed. What does this mean, and how can it be cleared so that the dishwasher can be operated...
Mine is doing the same thing right now. It started beeping again this morning after I wiped off the touch pad. I shut the power off to it at the box and when I turned it back on to try to make it work it just showed the Cr on the display.
Dec 05, 2010 | LG LDF9810ST Built-in Dishwasher
My Fisher Paykel dw60cdw2 dishwasher stopped working mid cycle and I cant get it started again even aftre switching power off and pressing reset.. All lights on the console are working except the number...
had the same problem and it was the microswitch that is behind the door skin which is associated with the lock mechanism. got a new one and away she went
Aug 04, 2010 | Fisher and Paykel Dishwashers
There is a very faint sound and you can't hear it anymore. It's almost like there is no sound. On my LG LDF9810ST.
It could be turned off... and the faint sound is air you can hear .....this site is for 'machine' problems it sounds like your LG does'nt have one. Best Wishes.....Helen
Apr 17, 2010 | LG LDF9810ST Built-in Dishwasher
LG WM2233H stop worrking in mid cycle, no displya
This has happened to me when the power has gone out. It doesn't display anything and all you can do is restart the cycle.
Jan 17, 2010 | LG WM2487H Front Load Washer
I have an LG Dishwasher model LDF9810ST. Error code E1 keeps showing (Water Leakage Problem) NO water problems anywhere to be found. I have a hard time shutting down the machine. It has had a new MAIN...
Are you draining the unit in the basement or under the kitchen sink?
If you are draining the unit to the floor you will need a new drain hose with a syphon breaker. This drain hose is factory installed on all new LG dishwashers.
The part # is AEM69493801
This is a known issue and may be covered under your factory warranty.
Depending on where you live a factory service tech may be in your area.
Could you explain the second problem further...Hard time shutting down?
Shoot me a E-mail @ omaharox@msn.com.
I am a LG factory service technician not a sub contractor.
Mike
Jan 08, 2010 | LG LDF9810ST Built-in Dishwasher
Will not come on.
Since the LG LDFxxxx family, including the 9810 all have a power button (and not just a door handle interlock switch that turns the unit on when you close the door, you have an internal problem that will not have a quick fix.
This dishwasher had a 12 month parts and labor and a 24 month parts-only warranty. If you have proof of purchase, I recommend you contact the LG support number in the owner's manual.
Good Luck!
May 24, 2009 | LG LDF9810ST Built-in Dishwasher
DU1100 Stops mid cycle.
main control cpu unit failing
needs to be replaced
May 09, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Dishwashers Logo
141 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
