Wireless Zmodo cameras won't connect to my modem. I have 2.4 ghz and wpa as recommended. Hard wire cameras work fine to my iPhone.
  • 21 Answers
SOURCE: Wireless and internet
1. Make sure that wireless settings are properly synchronized.
>> ssid/security key.
2. Check your computers wireless connection status
> Make sure that it is set to "obtain ip address automatically)
3. If still not working if computer is set to obtain ip automatically, try assigning static ip on wireless pc
> You need to know your router's ip address and dns
4. Disable firewall on wireless pc.
Posted on Jan 26, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
SOURCE: connect wireless linksys to 2wire modem
put the modem on bridge mode and set the pppoe on the lynksis router and that should get you going
Posted on Aug 04, 2008
compucure
  • 61 Answers
SOURCE: Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Posted on Mar 20, 2009
  • 5 Answers
SOURCE: wpa encryption for wireless g adapter
This is a known issue . A WPA encryption does not work for G adapters to N routers. Try to reduce the encryption to WEP and check . Im sure that will work.
Posted on Sep 07, 2009
Testimonial: "quick and accurate"
Cannot find NETCOMM.WIRELESS ADDRESS
Wireless Connectivity issues with Apple Mac There have been some reports of Apple and Xbox hardware experiencing issues connecting to a number of different brands and models of modems / wireless routers after a recent update. In some cases, this can cause the modem or wireless router to restart whenever a wireless connection is started from either an Apple or Xbox device.
There are currently two workarounds in place for this issue:
  1. Change from using WEP to WPA-PSK or WPA-PSK2 Wireless security (recommended)
  2. Downgrade the firmware on your device.
Changing your Wireless security is the recommended resolution for this issue. For assistance with doing this, Please refer to the model specific support page for the wireless security setup document.
Jan 07, 2014 | Apple iPhone 3G
Iphone 4s won't connect to wireless network
Hi Darren
What type of wireless signal does your new WiFi router support?
I'm guessing you got a new wireless ac router?
The initial run of the ac devices didn't support the older types of wireless signal (b,g,n).
However some of the newer I am fairly certain do.
Either way, the limitation is likely that iPhone 4s supports only up to n and only the 2.4Ghz version of n (not the 5Ghz version).
So Yes, assuming that's the problem, then going back to the wireless g router will fix the problem
However, if your new wireless router/modem does support the other wireless standards it could be that ac is the only signal type turned on. Or if it's NOT an ac device then it may be that the n signal is set to 5Ghz and not 2.4Ghz.
To find out you can typically login to a router/modem through a browser of a device connected to the network it's providing. Then try going to http://192.168.0.1/
If that's the correct address you'll see an interface to manage the router (you may have to login... not something anyone here can help with). If that address doesn't work here are a few more to try:
http://192.168.1.1/
http://10.0.0.1/
Good luck
You can see the specs for the phone here: https://support.apple.com/kb/sp643?locale=en_US
Jan 19, 2018 | D-Link Xtreme N DIR-655 Wireless Router
Wirelss router won't allow other devices to connect to it - eg kindle, iphone, but internet works fine on computer (which it's plugged into)...
Before you start :
The Following Steps Should be done on the computer that is connected to the router (Plugged with a cable)
Step 1 : Make sure you have internet access
Step 2 : Open Router Setup by typing http://192.168.2.1 in the address bar of Internet Explorer
Step 3 : Once you are at the router setup .. on the left side underneath Wireless you can find Wi-Fi Protected Setup
Click it
Step 4 : If it is asking for a password .. leave the password field blank and click submit
Step 5 : Disable Wi Fi Protected Setup and click apply changes
Step 6 : Now on the left under wireless click Security
Step 7 : If it is asking for a password .. leave the password field blank and click submit
Step 8 : Change the Security mode to WPA-PSK (you can also choose WPA-2 but sometimes it doesnt work )
Step 9 : Type a password (8 Characters , It is Case Sensitive)
Step 10: Click apply Changes
Step 11: On the left , Under Wireless Click Channel and SSiD
Step 12: Change the SSiD to a Different name , Change the Wireless Channel to 11
Step 13:Click Apply Changes
Turn On the Wireless Switch on the Computer (If you are using a Laptop to Connect between router)
Now try to Connect to this new network on both your wireless Computers and Ipad
Let Me Know if it Works
Aug 24, 2011 | Belkin (F5D5231-4) Router
My computers don't recognize my wireless network, all the lights are on the modem, router, i reset wireless router, even my Iphone goes straight to 3G and doesn't recognize the wifi in my house.
Did you set up the router? Lights don't mean much; it's not plug-n-play. You have to use the setup CD or manually login to it with your web browser (wired) pointing to http://192.168.1.1 and at least set up the SSID and security (WPA or WPA-2) key, then connect from each client using those same credentials.
Feb 21, 2011 | Linksys Wireless-G WRT54G Router
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Jan 20, 2011 | Buffalo Technology AirStation Nfiniti...
My ipad and my iphone wont connect to the wireless,
The password that my Iphone required was the 20 digit key located on the sticker as WPA-PSK. Hope this helps someone!
Dec 31, 2010 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
My wireless hp says router cannot find host name
Double check your physical connection. It should be this way
Modem > connected to Internet Port of the router
PC > connected to port 1
Laptop > can be wireless
Now you must power cycle your router and modem. Turn off router first then modem. Wait for 30 seconds. Power on modem first, then the router. You must configure the wireless settings on your laptop it doesn't connect automatically.
Jun 14, 2009 | D-Link DIR-625 (790069292637) Wireless...
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Limited connectivity
Hi Duneider!
It's normal that your computers will not connect after you enable a wireless security (WEP/WPA). You are getting a limited or no connectivity message because the wireless computers are not connected to the network using the network key or the password that you have used to setup WEP or WPA. There is no need in hard conding the IP address, all you need to do is reconnect to the wireless network using the WEP or WPA Key. If you will type the correct WEP or WPA Key, it will connect and automatically get the IP address again from your router.
May 08, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
