Question about Welding Tools
Hi i am buying a 250/300 amp ishto mig welder would you recemend that brand, or a rossi a better brand in the same size your help needed. Regards Peter F.
5 Suggested Answers
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: Hi just bought a aga 400 mig welder could any one
Yes
Posted on Feb 02, 2010
Testimonial: "Thanks Ken all is comming clear now"
SOURCE: Hi, we need an electrical
Hi if the cable has been severed, i assume you have BOTH ends? If so, then it is a simple matter to just strip back both ends of the cable and join color to color?
Alternatively, you would need a service and repair manual, I have searched but have been unable to locate one? so then the best bet is for you to contact the manufacturer, and ask for one, it may cost a few dollars but they are worth their weight in gold when servicing.
Sorry i haven't worked on this exact model, and don't have more accurate data.
Posted on Sep 15, 2011
  • 2210 Answers
SOURCE: changed polarity on the rossi 220 amp mig welder but still won't weld
What do you mean "it won't weld" ? Does the wire come out when you press the trigger? If so and there's no spark when you ground it then check the heavy relay that operates the heavy juice. Tell us what you have done and tried so far.
Posted on Dec 05, 2014
Changed polarity on the rossi 220 amp mig welder but still won't weld
Dec 05, 2014 | Welding Tools
My SIP ideal 240v mig welder keeps tripping garage and/or house power, what's wrong?
welder drawing high current.sounds like a earth problem with the house or the unit.
Aug 14, 2014 | Welding Tools
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
Rossi 220BZ Gas/Gasless Inverter Welder MIG MAG ARC Portable Welding Machine
The Rossi 220bz mig welder comes set up to use gas welding, that is with the Mig electrode connected to the positive terminal, inside the machine.
To use gasless mig wleding, the mig wire must be disconnected from the positive terminal inside the machine and reconnected to the Negative terminal - inside the machine. Open both the side coveres of the welder using a phillips screwdriver. Use a 13mm spanner to undo the hex nut holding the thick copper Mig lead to the terminal named positive, then lead it through the machine to the terminal on the oppisite side of the machine, labelled negative and screw it in place there with a 13mm hex screw. Be carefull not to bump any of the many electric parts inside the machine.
If you run the Mig welder in gasless mode with positive earth and positive elecrode it will blow the household electric fuse.
If you run the Mig welder in gasless mode with negative earth and positive electrode it will work, but the end of the Mig gun tip will get very very hot and start smoking abnormally from excessive heat.
But if you take the side covers off and rewire it (takes about 10 minutes) to negative Mig Electrode, the Mig gun tip remains cool and does not overheat. You will have to cut just one white cable tie, to get an extra inch or so of free Mig cable, so the thick copper Mig lead will reach accross to the terminal on the other side of the machine named negative. Stick the earth lead at the front in the positive terminal.
I did this on my Rossi 220bz mig welder.
http://www.weldequip.com/gasless-mig-wire.htm
Jun 25, 2013 | Welding Tools
How much does this welder cost?
Hi:
That welder in new conditions should cost about 350.00 dollars. Used probably just 120.00.
Oct 17, 2011 | Firepower Flux Core Wire Feed Welder 88...
I need clarke mig welder partes for the gun on a 130en. I can't find them any place, can you help me find them. Thank you.
Hi:
It will be better to adapt a new gun. Go to your nearest Praxair (www.praxair.com) store and ask for a tweco mini gun with a clarke adapter. Tweco accesories are available at ALL welding stores and it's a cheap gun also.
May 24, 2011 | Clarke Power Products Clarke 130EN...
I have an old mastercraft 110 volt ac stick welder model 110-104 have not used it for years have lost the instruction manual plate on the machine says primary voltage is 115 and primary amperage is 26.6...
35 amp should do nicely however make sure the mains cable is of the correct size, better still, get a qualified Electricion to install it.
Usualy 30amp could be used but using 35amp gives you some reserve
Oct 03, 2009 | Miller Electric Mfg Co 903505 Invision...
Welding Tools Logo
384 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
