What dust this mean - Computers & Internet
Symptoms bad thermostat
Maybe. Black dust can come from burned electrical components. What does the black dust smell like? Does the thermostat work?
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Jan 10, 2014 | Whirlpool Refrigerators
Leaking from right dust boot, when i say leak i mean the whole contents of the reservoir blows out of the dust boot
I am assuming you are talking about the power steering rack boot. This means the the seal on the end of the steering rack has blown out. You will need to get a remanufactured rack and pinion, install it, and realign the vehicle
Nov 11, 2013 | 2007 Dodge Caliber SXT Sport Hatchback
Are chalkboards unhealthy?
WiseGeek.com says:There are two separate issues buried in the question of chalk dust safety. In one sense, the main ingredients of chalk dust are considered to be non-toxic, which simply means they do not pose a threat when ingested. In another sense, chalk dust can and does accumulate in the human respiratory system, which means it can create long-term health problems due to overexposure. In short, swallowing a piece of white chalkboard chalk won't kill you, but breathing in chalk dust for a number of years can create or trigger respiratory problems.
Jan 24, 2013 | Office Equipment & Supplies
How do i fix over heating xbox360
It most likely means your xbox has alot of dust of the inside and the dust is slowing down the fans
To fix this either open the xbox and clean out all the dust or use a air compressor and use the air to get it out. I've trihe dustfirst and my xbox is running perfect, as for the second im not sure if the air compressor will take out all the dust.
Jul 23, 2012 | Microsoft Xbox® 360 Core System Console
How do i remove dust from a rear projection tv
If you mean is how to clean the inside dust?..You can used vacuum cleaner and brush to clean or remove the dust..
Dec 17, 2011 | Samsung HLR5067WX 50" Rear Projection HDTV
There's black dust all over our furniture, floor,computer , etc. it's coming from our heating vent and i have kids. could this dustpossibly harm them? and is there a specific name for this dust?
Yes this dust can be harmful for all of you. This is dust coming from the flue and the burners. which means that they need to be cleaned extremely well. I would call a technician out and have them service the heating unit. They will also check for a cracked heat exchanger
Jan 02, 2010 | Empire DV-215 Direct Vent Natural Gas...
Do i need a filter for my fan in my laptop its a gateway mx6450
f you mean a dust filter, no, it's not required, but it helps keep the dust out of your case, so the laptop doesn't heat up as it would without. If you don't have a dust filter, you can solve the heat problems (when fans get really loud all the time) by opening the case and cleaning out the dust. (every 3 months or so)
Dec 04, 2009 | Gateway Computers & Internet
Dust on drum
check corona wire, slide the blue tab 10 times check both side of drum if there is an toner on the surface of the drum try to clean it with metal polish and a cotton cloth
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
The fan hums constantly. Does this mean that
When Fan start giving noise then it needs to be replaced.
Apr 24, 2009 | Samsung HL-S5086W 50" HDTV
Rolling screen
them dang old dust mites... but seriously blue and red means you lost your green. the rolling means also your vetical sync is gone ....perhaps you hit a setup button ...take a good look and see if a button pushed in or sticking around where you dusted.to unstick you need a service man.
Aug 31, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
