Question about SINGER 7470 Sewing Machine
How do I open the case of a Singer 7470 to adjust the timing?
5 Suggested Answers
SOURCE: Using Singer 7470 for the first time, and my
1. Take bobbin out and re-insert and thread.
If that dosen't work, try:
2. Take bobbin out and bobbin case, clean area and re-insert bobbin case and bobbin.
3. Re-thread the top thread that goes to the needle. (Sometimes the thread dosen't hook to the "Thread take-up"(page 6 on manual). It pulls the bobbin thread and the bobbing becomes loose inside the bobbin case.
4. Wind a new bobbin (Sometimes a bobbin might wind thread to lose) Do not wind thread to the edge of bobbin.
If that dosen't work, you should take it in to be serviced...Somenthing might become loose that only a technitian can correct.
Also check manual for troubleshooting.
Good luck.....
Chickiefl
Posted on Jun 10, 2009
bargainbox
  • 1388 Answers
SOURCE: singer 7426 timing off
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
Testimonial: "very helpful...thank you"
  • 54 Answers
SOURCE: The needle is hitting the metal under the bobbin
you machine is out of timing bad,,may have a broken gear.
Posted on Aug 19, 2010
  • 244 Answers
SOURCE: I have a Singer confidence
First, make sure you have the bobbin placed correctly in the bobbin case. There should be a diagram showing the correct placement and thread path. Your upper tension should be set at "3." Then be sure the needle is inserted correctly...the groove should be toward the front of the machine. And just to be sure, recheck the upper threading. Sometimes one missed little thread guide will cause the problem you're describing. I hope this helps and that you can get your machine running again!
Posted on Nov 11, 2010
Hi, I have a singer confidence 7470 sewing machine and the needle keeps hitting the bottom of the bobbin. I need to know how I can adjust the needle.
Try a brand new needle. If the old one is bent, that could be why it is striking. If the new needle doesn't resolve the issue, the machine most likely has a timing issue. You can search for multiple web sites and videos for discussions and instructions for sewing machine timing issues. Or you can take it for service.
Oct 04, 2016 | Singer 7470 Confidence Sewing Machine
My singer 7470 i start to sew and clicks and bunches the cotton then the bobbin catches on the hook
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
if these suggestion don't help then the machine needs to be checked to see if it needs some type of adjustments
Mar 19, 2014 | Singer 7470 Computerized Sewing Machine
Adjust timing
Presuming your needle is clamed in fully up position & is not needle bar height problem,this needle/hook timing should get your local sewing machine technician to get it adjusted correctly.
Oct 24, 2013 | SINGER 7470 Sewing Machine
Bottom thread too loose; tried rethreading top thread, cleaning bobbin case, refilling bobbin, changing needle, adjusting top tension
Check for correct bottom thread tension.
It's provided by a flat spring on the bobbin holder.
When the bobbin is correctly installed, pulling on the thread
should meet with slight resistance, and the bobbin should spin without
trying to jump out of the bobbin holder.
Dec 18, 2010 | SINGER 7470 Sewing Machine
I have a Singer confidence 7470 and when i sew something the string on the bottom part of the material gathers....i tried playing with the tension adjustment but it didnt work Your help would be...
Nov 11, 2010 | SINGER 7470 Sewing Machine
How do I get the case open to get something dropped inside.
Have a look at the manual for this machine, it should tell you.
http://www.singerco.com/accessories/manuals.html
Just type 7470 in the search box and click search.
On the next page, appears a list with two options. Click on the free download option to download the full instruction manual.
I hope this is helpful for you!
Sep 17, 2010 | SINGER 7470 Sewing Machine
Bobbin thread is loose
Lift the presser foot and pull out 8" of thread. Lower the presser foot and try sewing.
If this does not solve the problem the timing may need adjusting and this should be done by a Singer repair service.
Apr 20, 2010 | SINGER 7470 Sewing Machine
My singer 7470 is skipping stitches on the left hand side ie. if im doing letters it misses the bottom 1/3rd. and other wider patterns misses about 1 in 12 ? i have cleaned bobbin case and it has obviously...
Take the machine in for service by an authorized Singer tech.
Hitting the bobbin case may have knocked the timing off and the shuttle may have to be replaced.
Trying to fix this yourself may lead to more problems and additional expense.
Mar 27, 2010 | SINGER 7470 Sewing Machine
SINGER 7470 Sewing Machine Logo
135 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
