BU-80 powered subwoofer has static when played, checked speaker itself and is fine, think is something in the controls, what can I Do?
  • Audio Player... Master
  • 5,391 Answers
Do the controls crackle when you move them? If so then you need to spray them on the inside with Servisol Video 40 or other non corrosive switch cleaner. Not WD40.
Other causes are Electrolytic capacitors and faulty output devices. Often the main amp device.
My subwoofers cut out after 30 seconds of use but work fine during the 30 seconds...my fuses are all fine and i'm running thick wire with an 80 amp fuse connected off battery...I have a lanzar vibe286...
If it's only your subwoofers cutting out and your speakers are still playing and all, try turning gain down on sub amp and see if that fixes it. I know if I crank my amp too high it kicks itself off to try to keep itself from blowing.
Aug 21, 2011 | Car Audio & Video
Bought new Infinity 8" speaker
hook them up and play something,, the speaker should bounce "out" on bass sounds, if it pulls "in" switch the wires
May 04, 2011 | Infinity BU-1 Speaker
Is there a on of switch and is the green or red light to be on
There is no main AC power switch on the BU series; it's in standby mode whenever it's plugged in.
When playing music normal LED color should be green. After no signal for 10 minutes or so it will turn back to Red (Standby)
Nov 23, 2010 | Infinity BU-120 Subwoofer
Is it possible to hook the infinity bu-1 subwoofer to a home theater system where the subwoofer output is straight power say it"s like 25 watts coming out of that one channel and before the original...
In general higher speaker impedance is safer than lower impedance for the amp. Don't expect anything impressive re: audio output from a passive (unpowered) sub if your HTS says it pushes only 25 watts. Without frequency bandwidth and distortion noted the spec is virtually useless as a comparison.
The BU-1 is a powered sub that accepts either RCA Line Level or HIGH LEVEL amplifier power. If you use the latter, impedance is a non-issue because the input feeds the BU-1's internal amp, not the speaker directly. You should be okay.
Perhaps if we knew some specifics about the HTS we could do more than guess.
Jul 21, 2010 | Infinity BU-1 Speaker
WHAT FUSE IS USED IN THIS SUB
The fuse is external, mounted on the back. I think it also holds a spare fuse. Rating is marked next to the fuse holder.
Mar 03, 2010 | Infinity BU-80 Speaker
Subwolfer does not play with cd's, plays fine with dvd's
Some amplifer's have controls to switch subwoofers off in some modes. Have you accidently switched it off?
Dec 13, 2009 | Yamaha Digital Sound Projector Home...
1999 Toyota RAV4
Hey Robert. It could be one of a few things. I had trouble with my speakers too.
If you still have the factory head unit in your car, the static may be because the speakers are damaged.
If you have a new or non factory head unit in it and you have the factory speakers in the car, the speakers will have a static sound when turned up because they have trouble supporting the amount of watts and power that are being supplied to them.
Another problem I think of when you say static is the metal and plastic or your car "rattling" against each other when bass shakes the area around your speaker. If that's the case, you just nee to put something in there that surpresses the amount of vibration that comes off your speaker and flows into the speaker mount.
Hope this helped.
Jun 12, 2008 | 1999 Toyota RAV4
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
Static in speaker
Check to be sure you ran the audio wires away from the power supply wiring. I always run the audio down the Passenger side and power to amp on Drivers side. Also check you Ground, and be sure you have metal to metal, no paint obstructing the power.
Nov 23, 2007 | AudioBahn AW150T Car Subwoofer
 Grubhead
Grubhead
