Question about Singer Sewing Machines
I have a Singer 99-13 with knee control. I wound bobbins but can't get it to sew. Is there something that turns it over to sewing? Thanks. Karen
  • Singer Master
  • 5,220 Answers
On the 99-13, you wind the bobbin with the balance wheel in the stop motion position. Thus during bobbin winding, the needle mechanism is disconnected from the rest of the machine. You probably need to tighten the set screw on the balance wheel. The screw is in the center of the balance wheel on the right hand side of the sewing machine. Hold the balance wheel while you turn the screw away from yourself. (You hold the balance wheel and turn the screw over towards you for winding.)
The manual for the 99-13 is available from Singer on their manuals page: http://www.singerco.com/support/instruction-manuals . The direct link to the manual is http://www.singerco.com/uploads/download/9d4377811af9ffbbaa1b8efd50ea962c142a66d9.pdf . Look at figure 5 on page 7 (page 4 of the PDF) and then page 10-11 (page 6 of the PDF) for the bobbin winding directions.
I hope this helps.
Posted on Jan 03, 2017
How to switch the machine to work from putting thread to bobbin to work to sew is there a swith . my machine is singer sewing machine mon ami 387
Perhaps an instruction video or your user manual would be helpful:
SINGER Sewing Machine Threading Tutorial
If you have wound a bobbin and now wish to sew, it is necessary to disable the bobbin winding mechanism.
Dec 07, 2016 | Singer Sewing Machines
Bobbin refuses to be wound on self-winding bobbin machine. Bobbin does not turn. The thread is winding continously on the bottom of the bobbin basket. Need help.
Just off the top of my so-called head, it sounds like something in the bobbin area is not seated correctly. However, I would recommend that you do a search on FB and Yahoo interest groups (also on PSW software); it's members are MOST helpful, and will be glad to work with you to resolve this problem.
Jul 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
Why is thread is making multiple loops around bobbin
are you using pre-wound bobbins? or bobbins you've wound yourself? they might be too full or over wound (too much thread) this happens with pre-wound or some you've wound yourself. Also make sure you are loading the bobbin correctly. You also might try another bobbin, as sometimes they can get warped if they are the plastic kind.
Jun 27, 2014 | Singer 4423 Sewing Machine
I have a singer 201 knee control and I love it until today.
try these suggestions
rethread the machine top and bobbin, using every thread guide
try a new needle--one for the fabric being sewed--make sure the needle is inserted correctly into the needle holder
make sure the thread does not come off the thread take up lever
try a different bobbin
make sure the bobbin is turned the right way in the bobbin case
clean under the needle plate and in the bobbin area for lint
Oct 29, 2013 | Singer Sewing Machines
Singer 2263 will not sew because bobbin thread winds back around the bobbin
have you tried changing the needle?
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint
make sure the bobbin is inserted correctly into the bobbin case & also wound correctly
May 14, 2012 | Singer 2263 Mechanical Sewing Machine
Singer touch & sew 640 bobbin won't turn
is the bobbin in the bobbin case correctly?
is the bobbin wound correctly?
try taking the bobbin out & turning it the opposite way
let me know if any of the suggestions work
Apr 07, 2012 | Sewing Machines
Bobbin keeps jamming while I am sewing
Check these two things first.. Pull the bobbin out and look at how it is wound. Is it evenly wound across the bobbin ? Is the bobbin moving with the thread coming out the right way? ie not put in the bobbin casing backwards.
Try a different bobbin to make sure it is not the above problems. If it sews ok then there's something with the way the bobbin is wound or inserted. Also make sure when you put the bobbin back in the machine you feel/hear it click into place.
If that's ok then check your needle to see if it is bent, or in wrong or the wrong type of needle for the machine (tho most new machines all can use regular needles...older machines sometimes required specific needles made for that brand). Try changing needles.
May 25, 2011 | Singer 3116 Simple
Solve Your "Singer 118 Mechanical Sewing Machine" Problem Now!
turn down the tension and check that the bobbin is wound in the right direction. Singer offers manuals on their website: http://www.singerco.com/accessories/manuals.html
Sep 16, 2009 | Singer 118 Mechanical Sewing Machine
Singer 626 Not sewing
First, give Mom all your Reese's Peanut Butter Cups.
Then, be sure the bobbin-winding function is not still engaged. Check it again, since on some machines, the mechanism has to be backed off until you hear a click, or until a light turns off. If that's done, check the tension on your top thread, since that's easier, then on your bobbin thread.
If the bobbin didn't get wound evenly (Like if you're hurrying) that will mess up its ability to let the thread flow out, so see if the thread on the bobbin looks as smooth as a new spool of thread.
I hope you got your costume together & had fun aside for that frustration. :^)
Oct 29, 2008 | Sewing Machines
Sewing Machines Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
