Question about Eureka Vacuums
Handle will not lock into place on Eureka The boss superlite 405A
ukvacfan
  • 328 Answers
SOURCE: THE BOSS SUPERLITE THE BRUSHES WON'T TURN
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Posted on Mar 06, 2009
  • 46 Answers
SOURCE: Eureka the Boss SmartVac just turned off and won't turn on
Make sure it is not the electrical outlet that has tripped. If not then you basically have 3 choices. Cord, switch, motor. A service tech. should be able to diagnose.
Posted on Jul 25, 2009
  • 8404 Answers
SOURCE: Eureka Boss 4D (5892BVZ) - Switch Replacement & Fried Wires
If you got the handle apart, Id say you can probably fix it yourself. You might be able to patch it but I would say to maximize your effortrs please visit RepairClinic.com to find the exact replacement parts you need. They also have expert advice and guidance available.
I hope this works for you.
a
Posted on Oct 02, 2009
  • 1206 Answers
SOURCE: Eureka the Boss Power Plus belt problem
it could be the beater bar (brush) has bad bearings at the ends or burs on the beater bar section the belt rides on,my money is on the bearings.
Posted on Jan 24, 2010
  • 52 Answers
SOURCE: bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Posted on Jun 12, 2010
How can I use my upright as air compressor to inflate air mattress
It would be difficult because your upright does not have an exhaust port where you can hook up a hose. You would have to attempt to funnel the air from the exhaust filter into a hose or tube.
Mar 08, 2014 | Eureka Boss SuperLite Bagless Upright...
Is the filter in the eureka superlite 26.0 vacuum washable or do I have to replace it?
is the filter in the superlite 26.0 washable or do i have to buy a new one
Apr 11, 2011 | Vacuums
The vacuum is blowing out a lot of air, doesn't ****
make sure the dirt cup is empty and the filter cleaned .. once the filter is clogged it wont work ...make sure everything is assembled correctly to seal the cup ... this nice little vacuum should work good except on deep carpet ..
Sep 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
Feb 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Eureka Wide Track Superlite vacuum roller brush motor
Don't know if you can find something that will work, Eureka doesn't make these motors available thru them. Try some local shops or a place that sells small motors.
Jun 14, 2008 | Eureka 431A Optima Bagless Upright Vacuum
Assembly
It may not just slide into place, you may have to knocj it into place, then put the screws in to secure it.
Mar 25, 2008 | Vacuums
Belt broke
The belt number is 60957, There should be some screws that you remove from the bottom and the whole bottom nozzle will come apart, then you can change the belt.
Feb 27, 2008 | Eureka Boss SuperLite Bagless Upright...
Vacuums Logo
29 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
