Question about Sewing Machines
My Bernina 830 sewing machine makes initial starting noises but does not come on, anything I can check? I've already unplugged and plugged it back in.
  • Sewing Machines Master
  • 11,200 Answers
Assuming it is an 830 Record (old mechanical, not the new computerized model). If it sounds like the motor is straining but the machine's mechanics are not working, then the machine has most likely seized from old, dried up oil.
This is the method I've used on multiple seized machines and works:
Wheel on right side that controls the needle up and down is very tight...
This is the oil port diagram for the 830 Record.
My Bernina 830 sewing machine makes initial starti - machine-makes-initial-starting-noises-cet1hzswr3i14loxp1ym3rzl-3-1.png
Posted on Jan 03, 2017
Cant get benina 830 to turn on
take it in for a service
could be foot pedal problem or motor problem
Dec 16, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
What is the difference between a bernina record 930 and just a bernina 930
At the present time, Bernina 930 Record and Bernina 930 are the same machine. Although, technically the name is Bernina 930 Record, referring to the mostly mechanical sewing machine produced in the 1980's. They are very coveted machines and one of the more popular models.
However, Bernina has, in the past few years, begun producing computerized machines and labeling them with the same numbers of older mechanical machines (makes things very confusing), ie Bernina 830 Record vs Bernina 830 computerized model. At this point in time, Bernina has not yet produced a computerized 930.
Jul 08, 2013 | Bernina Sewing Machines
Looking for a user manual for a bernina 840D
The Bernina 830 Record is probably close to your 840. Here's a manual for the 830 Record:
BERNINA Support Machine and Accessories Finders and Software Support...
Sep 03, 2012 | Bernina Sewing Machines
Bernina 830 Sewing Machine Won't Run
Hi!
Here is the manual to a similar Bernina sewing machine.
Hope it will help you!
https://manualsbrain.com/en/manuals/807311/?page=205
Nov 13, 2017 | Bernina Sewing Machines
Bernina 830, worked fine until today... think it
there is a board inside the foot pedal that goes out sometimes you can check this by flipping the foot pedal upside down and at the top right there is a small hole where you can adjust the speed with a flat head screwdriver but be gentle it breaks easy, if its out you can take it to a bernina dealer and they might have a reapired one or they can send yours off for repair since that part is repair only
Jun 26, 2009 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
