Question about Home
Blue light staying on Quadra-Fire pellet stove
4 Suggested Answers
  • 223 Answers
SOURCE: I have a Quadra fire 1200 pellet stove insert. The
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Posted on Jan 11, 2011
  • 4736 Answers
SOURCE: Quadra-Fire Pellet stove-Pellet pot fills.
Sounds lie an Ignition Box problem. Quadra Fire recently redesigned their Ignition Boxes, so your may wan to replace yours. In addition, contact Quadra Fire Technical Service and speak to Steve Tate. He's a real guru when it comes to this problem. Don't settle for anyone else.
Hope this helps solve your problem.
Posted on Mar 10, 2011
Testimonial: "Thank you...don't know who Steve Tate is but will definitely look into Ignition Box replacement."
robinwenz47
SOURCE: quadra fire pellet stove will
min firepot - do a neg 3 to neg 5 flame/height try running on auto
try mixing with a small amt of wheat - set to utility setting (regardless of premium brands)
pull thermocouple off and put back on - might need a new one but the upgraded firepot that comes with a new element might be all that's needed as an upgrade
Reasons to upgrade: The upgrade to the bottom of the pot to the element is much bigger. There is also a large opening at the bottom of the element mount to aide in air flow upward to the pellets
Upgrading the firepot that comes with a new element - be careful of the TC Sensor cable - use plenty PB Blaster (wd-40? White lightning?) - slowly rock bolts back and forth - don't break the bolts!
Remove old cover around TC sensor and replace with a new TC Sensor ceramic cover from Preston Trading Post - might help
If the thermocouple is heated and produces millivolts, it's good. If it has continuity it is good. - make sure conections are pushed inside well enough on the pins.
You can test the board. Unplug stove. Then pull the firepot T-couple connector off the board, making sure which direction it sat. Then install a jumper wire on the exposed pins. Make sure it is clips with plastic covers that won't ground out. After installing the jumper wire, plug the stove in and check the wall control. If the error code for the firepot t-couple goes away, the control board is good. If the code pops up again, the board is bad.
jump the thermocouple connector pins on the control board, plug the stove back in -should be no error codes - tweaking the pins on the control board for a better connection - sometimes works
Also visit iburncorn.com
Posted on Nov 28, 2015
Why does my quadra fire 1000 not lite..i checked blower moter ignighter could it be thermocouple?
Wood burning or pellet stoves create acid vapor. The vapor damages thermocouples faster than a gas stove.
Jan 17, 2016 | Cars & Trucks
Quadra-fire pellet stove auger does not operate
motor not turning cause could be motor burnt check fuses or at worse faulty mother board have some one to have a look at it
Oct 11, 2014 | Heating & Cooling
I have a quadra-fire 1100-i and I can not get power to the ignitor
Be careful how you read the voltage on the ignitor, as it has a low resistance and may not show a voltage across it. As is the case with most parts, you can use a line cord to hot wire the device to test it. Remember, the stove has a 10 minute exhaust fan timer when its first plugged in, so the ignitor will not light until this has timed out.
Nov 25, 2012 | Napoleon Pool & Spa
Quadra Fire Pellet stove-will not ignite
I own a Quadrafire pellet stove. I have had this thing for 10 yrs. It seems every year at the start of the season I have some kind of problem. I clean it at the end of the season completely. First couple of burns are fine then get a good cold day and it doesn't work. All the gaskets, the exhaust blower, ignitor, glass front, and exhaust piping have had to be replaced. Now I have a blinking red light in the control box and cannot find anything on line to help. Does anyone know why this red light blinks 3 times every 10 seconds inside the control box? It's not the call for heat light. Think I may change to a wood burning stove to many headaches.
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Quadra-Fire Pellet stove-Pellet pot fills. Motor is running but will not light.automatically shuts down after about 5 minutes. Cleaned out
Mar 10, 2011 | Heating & Cooling
I have a Quadra fire 1200 pellet stove insert. The convection blower does not stay on continuously. 2 min on 2 min off
lp
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
I have a 1985 Whitfield pellet stove that has problems
Check the basics first fuel (supply and quality of) Air flow and ventilation. If nothing obvious google {whitfield pellet problem]. My guess is that something is plugged up.
Mar 03, 2009 | Napoleon Auburn Pellet Stove Heater
My Quadra fire 1000 Pellet stove is not igniting correctly, the fire box fills with lots of smoke, the when it finally does the flame is erratic, extremely high and is giving off alot of black, and does...
Hi lovinthepine:
1st. clean the unit, inside and out! Clean fire bowl/pot, it'll have small'ish holes for air and a larger one for the igniter. Clean out all holes in fire pot! Make sure fiberglass gasket material between firepot and firebox floor is in tacked and not leaking. make sure ash pan door is closed tight. Clean finned heat-ex's, this requires pulling out the two heat exchanger cover plates inside the firebox., next pull the right side panel and remove neg pressure blower & clean. These can get cloged up with ash and half burnt pellets. Tall flames & black smoke mean the unit is out of adjustment. Try closing up the pellet feed plate some, it's located in the pellet hopper area. Adjust opening smaller and wait 15 min, takes that long for change. If that doesn't get it, try opening the positive pressure blower's restrictor plate some. Remove left cover panel & find semi funneled blower cover plate, loosen screw and slide plate sideways +/- 0.25". If that doesn't do it, make sure all blowers are coming on, check for exhaust blockage in stove output/Flue sys. I hope that help ya, good luck!
C.B.
Oct 21, 2008 | Heating & Cooling
Home Logo
24 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
