Question about Miscellaneous
Have melex model 512e batteries good will not do anything
Where can I get replacement springs/shock absorbers for Melex cart in Aus
Arizona!
http://www.vintagegolfcartparts.com/Category/melex
Texas!
http://www.discountcartparts.com/index.php/contact-us/
Perhaps a motorcycle supplier would make some Koni type shocks for you. They take the length, ask the weight, put the springs in, put the top and bottom bushes in and that's it. You have adjustment by a collet that puts more tension on the spring and also air damping. Like these
http://www.bike-revival.co.uk/exp.html
Or how about asking direct to Melex Australia?
http://www.melex.com.au/
Jul 25, 2016 | Golf
Do you sell a battery for my sylvania laptop model#SYNET07526 if so how much thanks denise
We do not sell anything. Go to ebay and type in your model number with battery for a good price.
Feb 19, 2016 | Sylvania G-Netbook
Why doesn't our Melex golf cart start after replacing batteries.
sounds like you have either a relay or computer that is bad, needs to be serviced
Nov 30, 2015 | Golf
Dish remote code for craig clc 512e
0382,0389.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 15, 2014 | Televison & Video
Wiring diagram , melex golf cart,model 212
I have a melex mod ha18cm and batteries are charge and its getting spark but not starting what should i do ?Also all the wires are connected .
Jul 05, 2011 | Car Audio & Video
Anything special to charging the battery on a 2000 model CLK 320 Cab?
If will not charge compleatly try droping a single regular asprin in each hole . This will clean the grids in the battery and will not hurrt anything, Good luck to ya.
Mar 26, 2011 | 2000 Mercedes-Benz CLK
What type of CMOS battery should I buy for HP compaq - d/530s/P2.66/40bc/512E/4UK?
Being a desktop, take the side off and take a look. They are usually 2032 or 2016 button style Lithium Ion.
They can be purchased from most Jewelers, and Hardware type stores.
Feb 17, 2011 | HP Compaq d530 SFF PC Desktop
I format my pc.but sound does not come.so i need the sound card.
You can download the sound drivers (and any others) for your model from http://h20000.www2.hp.com/
May 03, 2009 | HP Compaq d530 CMT PC Desktop
Miscellaneous Logo
12 people viewed this question
Top Miscellaneous Experts
Brett
Level 1 Expert
Valmae Patterson
Level 1 Expert
cwcollectr
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
