Question about Ovens
Switch for main oven broke - Ovens
    Top Expert:
  • Ovens Master
  • 48,245 Answers
Call the service agent spares and have them fit a new one
Problem with electronic oven controls - can't turn off oven
Maybe you broke a mechanical switch. To do this, pull it by pulling yourself, use a screwdriver if necessary. You will open the pin which is the switch. You take the pliers and turn off the switch to neutral. <br><div id="inner-editor"></div> If you have an electronic switch, turn off the oven from the mains and call a service technician.
Sep 06, 2017 | Ovens
Oven not working front lights for main switch and thermostat and internal light not coming on oven wont heat only fan is coming on oven 1 year and a few months old
Check if a overtemp fuse has beem avtivated. You will need a multimeter. Check for burned wires on function switch and thermostat. And check functionswitch for burn marks. Function switch = main switch
Feb 13, 2016 | Ovens
Replace light inside oven
Switch oven off and switch main oven switch on wall off if no wall switch, switch off at main switch board.
Open door and check glass cover if it screws off or has retaining screws. be careful as it could be hard to loosen, once loose unscrew lamp anticlockwise slowly as lamp my break off base if tight move side to side very little and unscrew. get replacement and replace opp to removal. Switch on main switch and test.
Oct 17, 2014 | Ovens
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Main oven bulb changed now new one will not go out.
There is probably a problem with the oven switch. If you are careful, you can, after switching off the mains, remove the oven light switch, pull off the live terminal and insulate it. The turn on the oven mains again and see if the light still comes on. If it does, there is wiring problem. If it does not, the switch is faulty and needs to be replaced.
Feb 05, 2011 | AEG D5701-4 Electric Double Oven
The main oven is not heating up on the fan oven setting
If the fan is working o/k, then you need to replace the oven element, located at the rear of the oven compartment behind a removeable cover.
Nov 06, 2010 | Zanussi ZHQ575 Electric Double Oven
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Power running through neutral wire
If you are getting power on the neutral that usually means the neutral is open (broke). To confirm this check the voltage on your 2 hot leads. You may need to check the voltage when the oven is on. You may find high voltage on one leg and low voltage on the other. The high voltage would fry a fan (so would low voltage for that matter). I hope this helps. Sorry I don't know more.
Jan 30, 2008 | Ovens
Ovens Logo
26 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
