Copying black line (only when using feeder)
Our copier unit DP-2330/3030 has recently begun copying a black line onto our papers. How do i determine where the line is coming from? and how do i fix it?
  • 53 Answers
Which way is the line oriented? If it's vertical, it's probably a scratch on the drum. If it's horizontal (and repeats at fixed intervals), its spacing will help determine the circumference of the part that is causing it. Contact the manufacturer or post more details here.
Posted on Jul 21, 2009
How do i stop my sharp mx 4111n printer from printing with line on the paper
does this happen when printing? or copying? if printing check the fuser, image /drum unit What color is the line replace that image unit, if copying does it happen thru the doc feeder ? if so place on the big glass and make a copy if it goes away the its the doc feeder slit glass that is small glass use by the doc feeder, big glass not used by the doc feeder when copying or scanning
Feb 17, 2015 | Sharp Office Equipment & Supplies
Tip
Black lines when sending faxes or making copies
I've been getting many calls asking me why their fax/copiers/printers are getting black lines when they send faxes and making copies while using the automatic document feeder, and not when they open the document feeder and use the glass.
What happens, when you fax or copy papers that has white-out or some material that can flake off, it gets embedded on the ADF glass and the unit thinks its part of the paper.
99% of the time, what needs to be done is to clean the small glass, usually using fingernails to scratch off the dirt, or using a lint free cloth slightly moistened, should do the trick. Just go over it several times until it comes off.
If the lines are thick, it usually indicates a damaged scanner assembly, in cases with the Brother machines, not expensive to fix. With other units, its a different story, either because they do not sell the scanner assembly as a part, or units are sent in for whole unit repairs.
on Jun 08, 2010 | Office Equipment & Supplies
Why is there a Black line on paper when using feeder on sharp copier?
The black line is a build up of dirt or ink on the glass where ur copier "sees" or reads the image that is being copied. Cleaning of the unit is reccommended and should fix ur issue
Aug 01, 2014 | Sharp MX-M232D Multifunction Copier
Black line on paper when ever i photocopy any document
clean glass - if only when copy from document feeder, check the narrow glass strip at extreme left side - use alcohol or window cleaner. You can place the paper with mark on glass to locate exact area to check
Oct 31, 2013 | Panasonic DP-8016P Copier
Our copystar is creating a dark line on the right side of the paper
There are a number of things that can cause this problem, below are a few things you can try.
1. Remove the process unit out as if you were going to remove a jam. There is a green piece of plastic used to clean the main charge unit. Slide it to the left then back to the right. Make sure it is seated all the way to the right in it's home position or it can cause black lines.
2. If you have a document feeder on the copier is the line only when using the document feeder?
- Determine if it is by making a copy from the glass.
- If it is only when making a copy from the document feeder then clean the small **** glass just to the left of the large glass. This glass is used only when making a copy from the document feeder.
3. If you wipe your hand across the copy and the toner wipes off then fixing unit should be replaced.
I hope this is helpful,
Shawn
Feb 18, 2011 | Copystar CS-1500 Copier
Black line on copies when automatic feeder is used
The problem is most likely cause by ink, correction fluid or lint blocking the scanner pickup. Check out the tip we have posted here that should get you back going again.
http://www.fixya.com/support/r3639811-black_lines_faxes_or_copies
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 03, 2010 | HP Officejet 5780 Printer
Thin black line appears on all copies ONLY from form feeder
Hi sounds like you have a particle on the window in the feeder. What hapens is when the light scans the paper your copying the particle of dirt shows up as a line. Simply clean it with a soft cloth and mild window cleaner. . Thank you for using Fixya.com
Feb 09, 2010 | HP Laserjet M2727nf Multifunction Printer
Full page vertical line appears on copy fed pages.
Open up the document feeder. You will probably find wite-out on the scanner glass.
Dec 12, 2008 | HP Officejet 5510 All-In-One Thermal...
Single black line down center of newly copied page when using Auto feeder to copy
I had this same problem but after while it went away - so my solution would be to just keep using it, and perhaps it will solve itself.
Jun 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
143 people viewed this question
jasbo
jasbo
