Question about White Sewing Sewing Machines
How do you get the retractable spool holder to come up? on the 8600 White machine.
4 Suggested Answers
  • 11 Answers
SOURCE: Brother xl 2230 - cannot fill spool as holder does
The Rubber O-Ring on my XL-2230 turned into a gel like substance.The rubber actually decomposed. So I went to the hardware store and found a replacement O-Ring made of a better material. Winds great now.
Posted on Jan 28, 2012
SOURCE: I have a janome 760 platinum jem and the thread spool that flips up and down broke off. I don't think it can be glued, can that part of the machine with the spool holder be replaced? is it expens
I've check different sites for one & can't find any, here's what I
suggest, check with a sewing machine shop in your town & see
if they can order one
or email these sites about one, give the name & model number
of the machine
sewvacdoctor.com
a1sewingmachines.com
Posted on Jun 08, 2012
99rannellis
  • 12036 Answers
SOURCE: need a singer sew mate thread holder
Search the internet for:
Make + Model + the word "Parts"
If unsuccessful, a spool pin can be made using a small wooden dowel, a cut off plastic knitting needle, or taking a pin off a donor machine, or a variety of other items. There are also standalone thread stands that can be purchased that will set on the table behind your machine.
Posted on Jan 28, 2016
Replacing spool holder
If you search online for:
Make + Model + "replacement parts"
you may find a replacement. Otherwise, you can usually manufacture a spool holder using a drinking straw, wooden skewer, or something similar. There are also standalone spool holders for sale at various web sites. The spool holder doesn't necessarily have to be attached to your machine but can set behind or to the side of it. Some sewists throw the thread spool in a big coffee cup and just let it bounce around in there.
Jul 29, 2016 | Sewing Machines
When the needle is not pulling the bottom tread
is this the first time you use a sewing machine? if you are very familiar with the way the thread is pulled out of the bottom spool, I'd say you need a technician, here is how to install bottom spool in case you don't know. after filling spool, pull thread out through the small gap on the side of the spool holder, then holding the small arm on the holder outward insert the spool holder in to the socket and release after fully inserted. after that the thread should come out the top by manually turning the machine to lower needle
Dec 24, 2014 | Sewing Machines
I BOUGHT A WHITE 445 AT A GARAGE SALE, BUT I CAN'T FIND A PLACE TO HOLD THE SPOOL OF THREAD ON TOP.
There are 2 retractable spools on the top right of the machine. Just pull them up with your fingers.
Jul 12, 2011 | White Sewing Sewing Machines
I inherited an Elna 2002 and I can't figure out where the spool of thread goes on the machine. There are two round metal pieces surrounded by a piece of felt on the right side of the machine but nothing...
Can you pull the metal pin up, I know that the Elna 5000, 7000 and 9000 all had retractable thread spool holders. There might be a little lip on the edge of the metal pin that you can grasp with your nails to extract it upwards.
Apr 27, 2011 | Elna 2007 Mechanical Sewing Machine
I just inherited an Elna 2002 machine and I can't figure out where the thread goes on the machine. I've looked at pictures of the machine but there's not a holder on my machine for the spool. There are...
tally_girl_22.jpg You need to pull them up from the retractable position for storage and transport, many Elnas have the retractable thread spools like this to protect them from breakage.
My LS2125i will sew a straight stitch but when I turn it to a zigzag stitch it takes a couple of stitches, then all of a sudden the top thread on the spool holder goes... whirl and winds the thread around...
sounds like your thread is getting caught in the thread spool's thread keeper notch. Make sure you use the spool holder disk with the closest size to the spool of thread to help prevent that. This is pretty common with old fashioned spools like coats and clark spools.
My brother suggests that i make sure the spool unwinds in a certain direction. You might check your manual to be certain the thread is unwinding the correct way.
Good luck.
Dec 18, 2010 | Brother LS-2125 Mechanical Sewing Machine
My dad has just bought a second hand elna lotus sp sewing mashine and does not know how to get the spool out can you please help him he said it has type 35 on it
Look in the back. By the lever you will see a white knob on a spring. Pull this down, put it in the bobbin; lift out. This is the bobbin take out method. Hope this helps. Keep this machine. It is great and only increases in value.
Nov 16, 2010 | Elna Sewing Machines
Spool is bouncing on spool pin
Get a stand alone spool holder, sometimes the spool pins arent high enough to support the thread or you can try a thread sock
Jul 16, 2009 | White Sewing Mighty Mender WW100...
Open Questions:
Sewing Machines Logo
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
