Question about Motorola Radio Communications
Won't turn on. Tried all kinds of batteries. I bought a pair a few years ago. Model T9500 FFC ID:K7GT9500. The other motorola works without any problems. Recommendations?
Forgot to menion that the I used the same batteries to test both talkie-walkies, conclusion - it's not the bateries
Benimur
  • 6966 Answers
SOURCE: Motorola T5700 Talkabout Series
It would seem that this is a problem with the contact/switch of your Motorola T5700. When a headset, ear piece or external speaker is plugged in, an internal switch transfers the connection from the speaker to the external. This is better illustrated in the image below.
Initially, you can try an electronic contact cleaner. If that doesn't work, you may have to open the unit and manually scrape off any corrosion from the contacts/terminals or slightly bent it to improve contact.
Hope this be of some help/idea. Pls post back how things turn up or should you need addition al information.
Good luck and kind regards.
Posted on Nov 04, 2007
BillB-SA
  • 2761 Answers
SOURCE: motorola k7gt9500 police channel in manassas virginia?
Your Motorola radios operate in the FRS/GMRS band, which is at 462 MHz. Police, fire, EMS services, etc. operate in the 150 or 800 MHz bands. Your radios cannot receive public service transmissions, and they cannot be modified to do so. Monitoring public service transmissions will require a scanner.
For a comprehensive database of active frequencies and services in your area, visit:
www.RadioReference.com
For a good listing of available scanners, visit:
www.ScannerMaster.com
Posted on Jan 02, 2010
BillB-SA
  • 2761 Answers
SOURCE: Is Bell South walkie talkie compatiable with other
Some number their channels differently, but all FRS/GMRS radios operate in the same mode and will have at least some frequencies in common. Check the channel/frequency lists for both radios and you'll be able to talk to each other.
Posted on Feb 28, 2010
eradiostore
  • 1654 Answers
SOURCE: I am trying to pair my motorola walkie talies
Here is a link to the user guide: http://www.motorola.com/mdirect/manuals/SX700_userguide.pdf
You will need to program the frequency, code and Qt filter (if any) to match. For basic operation set the frequency and then set the code and Qt filter (if any) to off (zero).
Best regards.
Posted on Apr 15, 2010
  • 56 Answers
SOURCE: Problems charging Cobra Walkie-talkie MT800 battery
Downloading the manual will now make the batteries charge?
apimom
Posted on Jul 23, 2011
Survelliance headset won't work anymore with motorola t9500
Try leaving the batteries out overnight and see what happens
Aug 13, 2014 | Motorola Talkabout® T9500 Two Way Radio
Mh230r
Take the radios back to a very basic setting with all special features turned off. If the radios have a Qt filter check to see it is turned off, and set your Code to zero (off) on both units. Also, check to see your battery is good in both units. Trade the battery with a known good radio to see if the problem moves to the other radio, is a simple test.
Jan 04, 2014 | Motorola MH230R Two Way Radio
I ptt and it immediatley 'roger beeps'
Beeping when you press the PTT button usually indicates a bad or weak battery. Check your batteries and charger. Clean contacts with a pencil eraser.
If you feel this is not the problem, then you have a radio problem. These radios are non-repairable, as parts and schematics were never released for them.
Best regards.
Dec 12, 2012 | Motorola Talkabout® T9500 Two Way Radio
Manual K7GT9500
You can download/print your manual here:
http://www.banoggle.com/Products/Motorola/manuals/T9500-manual.pdf
Dec 28, 2009 | Radio Communications
Motorola talk about t9500
Check the programming of your frequency, interference code eliminator (code) and Qt filter. Be certain all are identical.
If this does not solve the problem, take the radio back to a basic mode by turning off the special features. (Set the code to zero, the Qt filter to off, the roger beep off, the call tones off) Your radio should work easily without the extras. If the radio doesn't at this point, you have a bad radio.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T9500%20FINAL%20-%20English%20only%20all%20rights%20reserved%20and%20call%20center%20email%2004-24-07.pdf
Best regards,
Nov 16, 2009 | Motorola Talkabout 25-Mile, 22-Channel...
Won t charge
Download Motorola Phone tools and get a new battery for your phone.
The batteries go bad about once a year, sometimes longer.
if this helps you please leave a vote on fixya
May 21, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Motorola Talkabout 2 way radio model T9500
You might check your Qt filter to see if it is turned off. You can find the instructions on page 2 of the user manual.
http://www.hitechwireless.com/pdf/T9500RManual.pdf
Sep 08, 2008 | Motorola Talkabout 25-Mile, 22-Channel...
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Motorola bluetooth H500
A few days ago I paired my razor to my blue tooth1.gif and t was working just fine but the next day it wouldn't work and every time I tried to connect it it would say I NO DEVICES FOUND. I tried reseting the phone but that did not work and I don't know what to do. Can you PLEASE HELP ME!
Jan 27, 2008 | Motorola Mobility H500 Wireless Headset
Radio Communications Logo
44 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
