Question about OKI Office Equipment & Supplies
Hello I have an OKI C531dn printer that shows me a error message 069, what to do? help me
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Service Call
069:Error Malfunction of the NIC chip was detected
Does this error recur?
Yes Power OFF/ON
Replace the printer control PCB
Testimonial: "how to replace the printer control PCB? please tutto"
OKI 461 error C531dn LED Colour printer.Says the paper is wrong but it isn't! It's suggesting I have to load A5 paper although I am printing A4 and it's an A4 tray. Done loads of printing before.
I suspect you have sent the job to the MP ray and it wants you to put paper in it. Cancel the job and go back into the driver and make sure paper source is set to the cassette.
Aug 17, 2017 | OKI Office Equipment & Supplies
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Error message 381
pulling the paper out can damage the roller feeder. also make the roller out of sync with the other rollers, i think to reset it you will need to activate ink cartridge change this can some times sort out the problem. remove the cartridges and leave out it will reset and say not inc. when it does this put the inc back in and it should reset.
Jun 14, 2017 | Cisco Oki C330Dn Led Printer - Color -...
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
I'm getting a service error 02 in a printer oki b6100. How do I solve this problem?
The OKI B6100n Laser printer is a unique printer. These Error messages are to enable you detect the fault and resolve it if you can and the once you cant it resolve,u call the repairman.
The Service Error 02 means that there is a paper jam inside the printer and the only way to resolve it is to remove the paper from the indicated location on the printer.
You can also check the user manual on the CD ROM of the printer for more information and how to correct similar error messages on the printer.
Thank you.
Sep 12, 2011 | OKI B6100n Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
Replace the duct assembly
Dec 21, 2009 | OKI C9600hdn Laser Printer
Have an OKI Printing Solution C5800 color printer received the following error message: Check Toner cartridge 543K Toner Sensor error - have already changed the Drum and the toner. The error will not go...
Found this at
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Aug 08, 2008 | OKI Office Equipment & Supplies
Fuser temp. OKI B2500MFP
Don't Worry nothing is damaged.
The message usually shows when the electricity is off
it is easy! u just have to call to yr local service (Greece: +302310531334) and they will give u instructions to erase this message from the memory so as u can work again with yr oki.
THe instructions have to do with the menu on the oki display.
Mar 31, 2008 | Office Equipment & Supplies
Communication Error
Disconnect from pc, restart printer on it own, same prob then will need firmware reinstalled, hard drive replaced or even main controller, Job for a tec.
Works ok alone then driver issue delete and reinstall driver check cable too.
Dec 11, 2007 | OKI C5200n Laser Printer
90 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
