Question about Roomba Vacuums
I think I need a new battery for a Roomba 780. How can I order and make sure that is what I need.
  • Roomba Master
  • 20,907 Answers
    Genius:
  • 1,181 Answers
Will I have to get a new Roomba?
Take it apart look on u tube to do that and let it dry for several more days. BE very careful of the wires. Screws are easy. Don't disect it. I've had mine since 2007
Jan 26, 2016 | Roomba iRobot 780 Series Vacuum Cleaning...
My robot wont work even with a new battery
Once of the problems with batteries is they tend to corrode the metal contacts. Try lightly scraping on the metal battery contacts inside the Roomba and also on the battery with a small screwdriver...this creates a clean surface and allows conduction between the battery and the Roomba.
Dec 24, 2014 | iRobot Roomba 560 Robotic Vacuum
Where can I get a replacement Brush Guard for Roomba 780?
I have seen them at Meijer I repair many vacuums and that is the cheapest and best place to get them or guarantee vacuum and sewing center
Mar 20, 2014 | Roomba 780 Robotic Vacuum
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
Our roomba 560 wont charge have replaced the battery Tested the charing unit with another roomba that all seems ok put the uncharged battery into another Roomba but im guessing it now has a memory as this...
Try cleaning the battery contacts with a little rubbing alcohol or contact cleaner on a foam swab, or a bit of paper towel. Take a litle time, it doesn't always dissolve instantly. (Don't use a pink pencil eraser, it would scrub off the plating that prevents corrosion) Clean both contacts on the battery pack and both of the contacts in the Roomba. Make sure the battery is oriented correctly when you put it back in. Also clean the charging base contacts and the corresponding contacts on the Roomba itself.
I'm not sure entirely sure what you're trying to recover - the new battery pack, the old battery pack, or the Roomba itself - but since you can swap parts back and forth, you can clearly isolate the problem. The old battery pack might be rehabilitatted if you have the equipment to recondition it, but if it may not work. The new battery shouldn't have been harmed that easily.
Oct 25, 2009 | iRobot Roomba 560 Robotic Vacuum
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
Vacuums Logo
52 people viewed this question
Top Roomba Vacuums Experts
Lonnie Arks
D. E. Hev
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
