Question about Toshiba Televison & Video
Toshiba 32HL86 no longer receives HDMI signal - blue screen only for HDMI input. Do I need to reset something?
Tried different (smaller) HDMI cable from DVD to TV but only audio got through. then when I switched back to original HDMI cable got the blue screen. when I put the HDMI cable to my cable TV digital box, again just a blue screen. Do I need to reset something
5 Suggested Answers
SOURCE: Receiver: Pioneer Elite 72TXV Verizon
Called Verizon automated help desk. They rebooted DVR remotely and solved the problem.
Posted on Mar 29, 2008
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
  • 97 Answers
SOURCE: How to separate AUDIO SPDIF signal from HDMI and bring it to coax or optical input of AV Receiver
Get a hdmi switch
Posted on Sep 03, 2012
Testimonial: "now have simle device where hdmi video and audio enter, and video can go as output,but device can route audio to spdif optical,or even coax(rare).."
My vizio is blinking back and forth from the blue no signal screen to the actual hdmi input screen which is connected to a cable box. What is going on?
Have you tried a different HDMI input? (If available.) You may be able to test the cable box of PS4 using component cables to confirm that all but the HDMI is not working. You may try pushing or holding the HDMI cables to see if you can make the problem better or worse to identify a possible flakey HDMI socket.
Jan 03, 2015 | Vizio 26 Class Edge Lit Razor LED LCD HDTV...
HDMI cable does not work with Dish hd 612 box what is problem
Hi, Cheri Torres with DISH Network Customer Service here. There could be a few different reasons that your HDMI cable is not working. The cable could have gone bad, sometimes the cable is loose and you will need to make sure it is secure or when the cable was taken out of the TV or receiver it may have been accidentally damaged. What are you seeing on the screen when you have the HDMI cable plugged in? Please make sure that the the TV is on the correct input to receive the picture from the HDMI cable. You can also try to reset the DISH receiver box by unplugging it from the wall for 10 seconds. Another option you can try is replacing the HDMI cable to see if the cable has gone bad or been damaged. The last option to try would be to use the cable on a different device such as a blue ray player or gaming unit. If the cable does work on a different device then the receiver may be the issue. I hope this information helps and if you have any further questions or concerns please let me know!
Nov 01, 2011 | Akai LCT2721AD 27 in. LCD Television
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
Not able to get picture when connected to PC via HDMI
bbutler,
Your Toshiba can handle PC screen resolution up to 1024 x 768
Lower the resolution of the PC screen to somewhere between "640 x 480" and "1024 x 768". It will work just fine.
It's not likely that there is a any physical problem with either the PC or HDTV.
1. Right-click anywhere on your desktop
2. [Properties]
3. [Settings] tab
4. Slide the "Screen Resolution" pointer to the LEFT to adjust and click on [OK]
*DONE*
Oct 16, 2009 | Toshiba 37RV525R 37 in. LCD HDTV
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Toshiba hdmi ports not working
I talked to Toshiba about his problem, this morning. They said they have never hear of such an issue. I told them the TV was less than 1 week old, and would hope Toshiba would do something in response to my alternative action of returning both my Toshiba HD DVD and 52LX177 for a new brand. They said all they can do is have me go to a service center for them to repair it. 1 week old TV and DVD, $4000, for repair; I don't think so. I talked to two different people a Toshiba regarding this, with the same answer. Very poor customer support, especially for a higher end product like this. I think I have no choice but to change brands.
Nov 18, 2007 | Televison & Video
HDMI connection problem
On your TV set remote are you selecting the proper input; for example when you have different devices connected to the back of your tv set, dvd player, vcr, cable box etc; you have to tell the tv which device you want to use by selecting the right one on your tv remove input selection. Hope this was any help.
Sep 08, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
53 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
