Question about Sewing Machines
What do I do when the screen doesn't show anything but a line going up and down? on a Euro pro Model 9110
  • 14 Answers
SOURCE: euro pro 9110 sewing machine doesn't work
The direct number to Euro-Pro's sewing machine phone reps is 1-800-361-4639. I've read of other people calling and Euro-Pro sends the parts they need (no charge).
Posted on Mar 26, 2009
SOURCE: I have a Shark Intelli Sew 9110 Euro Pro. It was
There is no solution for that problem. My machine was doing the same thing, I returned it for "repair". Got it back 2 wks later and had the same problem. Just the other day, the machine did that, and then something "popped" and now the upper thread won't catch the bobbin thread. I called Customer Service and was told that if I want my machine repaired, I have to send them a check with the machine for $81! Your best bet...get rid of the Intelli-Sew and buy something that doesn't break every month or so!
Posted on Mar 19, 2010
  • 4 Answers
SOURCE: won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Posted on Jul 01, 2010
SOURCE: Shark Intelli-Sew Euro-Pro 9110 Manual. I need to
Here you go: http://dl.owneriq.net/6/6639ab83-34ea-0a44-d571-45fe5b5a50d3.pdf
Posted on Feb 18, 2011
SOURCE: I have a EURO -PRO
Hi janna
have you tried adjusting the top tension first?
if you have a drop in bobbin then it has to be adjusted at a sewing shop
the bobbin case you take out of the machine you can, using a small screw driver,,here's how
lower bobbin tension--
to test the bobbin tension,
remove the bobbin case & bobbin,,
hold it by suspending it by the thread,,
**** it once or twice,,
if the tension is correct, the thread will unwind by about an inch or two
if the tension is too tight, it does not unwind at all
if the tension is too loose, it will drop too much
to adjust turn small screw on the side of the bobbin
to the left is tighten
to the right is loosen
Posted on Sep 21, 2011
I need a manual for a euro-Pro sewing Machine Model: 9110
sewingpartsonline.com has a manual for the machine, I'm not sure the
link will work, if it doesn't follow the directions
go to shop by catagory
instruction manuals
choose euro pro
& find your model number
the manual is $11.99
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Jul 11, 2012 | Euro-Pro Sewing Machines
My sister just received the euro-pro 9110 as a gift but the manual is in spanish and she needs a manual in english - can you help?
This link no longer seems to exist:
http://www.euro-pro.com/europro/default.aspx
This link sells the manual (language not specified, but the contents are given in English) for $8.00 (U.S.)
http://www.tradebit.com/filedetail.php/32241226-euro-pro-9110-sewing-machine-manual
I cannot find a free english download - lots of broken links and circular links, though, since
"Euro-Pro" seems to have been bought by SharkClean.com, and their web site
http://www.sharkclean.com offers no support (manuals or otherwise) for any sewing machine.
Jul 07, 2011 | Euro-Pro Shark 9110 Sewing Machine
I need manual for my Euro-Pro X
Go to http://homeappliance.manualsonline.com/manuals/mfg/europro/9110.html. You can skip the offers that appear and you don't need to sign up for the sight, but you do need to agree to the terms and conditions at the bottom of the pop up screen. You'll then be able to download the complete user's manual for your machine without viruses and any other nasty things.
Happy sewing!
Jun 13, 2011 | Euro-Pro Shark 9110 Sewing Machine
I have a shark euro-pro model 9110, i bought it from a seller on ebay, but didn't try to us it until the guant. was up. it only works when the for peddle is not pluged in? i took it to a repair center and...
Call Euro-Pro's customer service for sewing machines at 800-787-7395. They can walk you through some solutions and if nothing else charge a labor fee of $40 to service it. The Euro-Pro model 9110 is supposed to have a 25 year warranty so you should be able get it fixed without too much hassle.
Oct 30, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Euro-pro 9110. just received one this weekend.. when i finally put it to use, it turned on and then a sound and off again.. it smelled like it burned.. anything I can do??
The 9110 has a 25 year warranty.
The manufacturer's information is:
EURO-PRO Operating LLC
94 Main Mill St.
Door 16
Plattsburgh, NY 12901
Phone (800) 798-7398
Hope this helps!
Nov 12, 2008 | Euro-Pro 373 Mechanical Sewing Machine
Won't catch bobbin thread
Apr 17, 2008 | Euro-Pro 8260 Mechanical Sewing Machine
Replacement foot pedal and wiring for Euro Pro
Here's a place that carries all the pedals. Many are used by various brands, and go under different names for different machine companies. The euro-pro manual has the manufacturer's name and the model #, or you can browse the drawings of pedals to match your own. My euro-pro 9110 uses a model also used by viking and huskevarna. This place carries the cords as well.
Good luck.
http://sewingmachine221sale.bizland.com/store/page36.html
Oct 31, 2007 | Euro-Pro Shark 60 - 384
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
