Playstation tv is broke how does i fixing, not sure what is?
Fix magnavox flat screen tv
Broken screen cannot repaired. It should be replace by a new one. Contact the authorized service center.
Nov 30, 2013 | Televison & Video
Antenna connector broke from tv. Can I use another IN connector, or is it easy to fix?
if it is the aerial connector whats broke make sure there is nothing stuck in the back of the tv then simply replace tv plug you can buy them fo about 50 pence
Aug 29, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My ps3 wont give off any sound
Hve you check your cables to make sure they are plugged and to make sure they are not broke? Try it with a different pair of sound cables. Also, make sure you have it on the right input.
Aug 15, 2012 | Sony Playstation 3 (PS3) Console
Well everytime we hook up the HDMI for the playstation 3 to the tv it says invalid format how do i fix this
You must make sure your playstation and your TV set are both set for the same video format (1080p, 1080i, 720p, etc.).
You can either go through all your HDTV formats until it synchs up (give each a good 20 seconds or so before moving on), or you can open the display menu for your PS/3 using a different video connection to your set (i.e. composite), setting both to match, then switching them to HDMI.
Feb 15, 2011 | Televison & Video
My ps3 was on a hd tv and the tv broke. now it won't work old tv
put it into standby(red light) and hold the on button until you hear three beeps, this will reset the video settings so you can play on standard def.
Nov 04, 2009 | Sony Playstation 3 (PS3) Console
Hdmi conection on the back of the ps3 is broke and needs replceing how do i do this
the easiest way is to send it to the shop you got it from and see if the can fix it (or another repair shop), another way is to run RCA to the TV instead
Sep 27, 2009 | Sony PlayStation 3 40GB System
I had a hdmi but my tv broke and im using difrent hook ups but nothing shows up how do i fix this so i can play agen
Make sure the system is turned off.
Then, hold down the power button for 5-6 seconds, until you hear a second beep.
The video settings will then be reset!
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
My playstation 3 broke i dont kno whats wrong
if your using the original ps3 cord that came with it (yellow white red) then you will have to use an HDMI cord and when you do use this cord then everything will show up on your tv including sound.
Oct 16, 2008 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
