Question about Nespresso Coffee Makers & Espresso Machines
Does any one know of an Australian seller or service agent for nespresso NY401 capsule coffee machines thanks.
  • 1,181 Answers
  • bryan jennings
    bryan jennings Jan 02, 2017
    Thanks D.E. Hev, tried nespresso and they can not find this model in their records.
Coffee pod stuck in machine
These machines are designed to use only Nespresso capsules. The UMilk, particularly, is susceptible to jamming if so-called "compatible" capsules are used, as the capsule is pierced electroncally, not manually as in most of the Nespresso range of machines.
Hope this helps, Rob.
Apr 11, 2015 | Nespresso U D50 Espresso Machine Color:...
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
My Nespresso Xn250140 U doesn't work. Why?
Check the hole where you put the capsule, are there any faults or obstructions visible? If not be very suspicious of your capsules, there are lots of brands of Nespresso coffeemakers and the capsules have slight variations between the different brands. The variations are almost invisible but enough to prevent the wrong capsules being used.
Jan 28, 2014 | Krups Nespresso Xn250140 U Coffee Machine,...
Nespresso umachine
are you useing the same type of capsules ?whaqt is the model ?
Aug 13, 2017 | Nespresso U C50 Espresso Machine...
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Why do Nespresso capsules squash?
the capsule must plop in at an angle, it it's straight it will crush and not work properly
Apr 18, 2012 | Coffee Makers & Espresso Machines
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Nespresso C100
I just posted that I had the same problem, and then I thought to call Nespresso. They suggested trying a different capsule, as nothing actually holds it in place, other than its own lip. Sometimes a capsule (or sleeve of capsules) will have a defective lip, and that will cause it to drop right through rather than holding itself in place.
Oct 23, 2008 | Nespresso Essenza C100 Espresso...
Coffee Makers & Espresso Machines Logo
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
