I have the menu bar up on my tv but the install button is greed out so I cannot do an auto tune. Any ideas thanks.
techman
  • 3130 Answers
SOURCE: Lost the Manual & can't tune digital channels, option not available on menu ?
Here is a link where you can down load a free copy of your customer user manual. Good Luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS120&LOC=3
Posted on Feb 03, 2008
ronpar
  • 27 Answers
SOURCE: grundig tv
on most tvs you go to menu then setup then if you have cable go to where it says (air and cable) select cable or if you just have a anttania select air then go up to where it says autoprogram then push to get you channels in you should be abale to use the remote or the front panel on tv if this don't work give me the make and the tv name. hope this helps if not let me know thanks randall
Posted on Jun 13, 2008
SOURCE: unable to re tune the tv
http://www.fixya.com/support/t933113-sony_trinitron_tv_model_kd_28dl10u
Posted on Sep 30, 2009
SOURCE: Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Posted on Oct 03, 2009
valiantma595
  • 176 Answers
SOURCE: can not tune the tv
My dear friend. A TV is a TV and TV's are many and varied. If you stated the model and what it exactly does, maybe I or other people could help you instantly. But since you have said little in relation to TV tuning, then expect a few guys to help you. But allow me to give you a hint that applies to almost all flat panel TV's, ok? Right. On every TV there is a MENU that gives you many options. First you need to press a button on the remote that displays component connection channels and TVincoming signal type. Since I don't know what brand of flat panel TV you have, I can only ask you to find and press the button on the remote that displays on TV screen the following component channels, that is DVT, AVT, Component 1, Component 2, HDTV1, HDTV 2, HDTV 3 and so on. Apart from DTV and ATV, from Component 1 to HDTV 3, these additional channels are for DVD players that also have HDTV outputs and BlueRay players and or Audio devices. If yout TV hasn't got as many channel input, then ignore this part. To tune your TV you have to first press the butoon on the remote to activate the onscreen channel as above, then scroll on DTV or ATV and, depending on whether you have Digital TV in your country or the standard high resolution Analog TV. Lets say you have Digital NTSC format TV system, select it and then press ENTER on your remote. In the menu you find and click SCAN. Depending on where you are, the TV will begin scanning all frequencies in your territory and possible interstates if the modulator is powerful enough to pick up weak signals. Most TV's have an inbuilt set-top box that boost the signal to give you a crystal clear pic. Now, after pressing SCAN, the TV reaches a signal with a clear pic, all you have to do is recognise the channel that comes in view. The instructions on how to save that channel are on screen and then you can configure it as, say channel 4, if the channel that appeared is channel 4, if not, try and recognise what channel had appeared and then configure it with a number, so when you press that number on the remote it will be the same channel you had stored in the TV memory. After you have done this, press scan again and it will scan to the next channel. Once the scanning recognises another clear signal and it is as clear as a baby's face, you have recognised the new channel. Try, find out what channel it is by looking at the screen, there is usually a visible TV station name or number embossed on the lower corner of the screen, once you know what station that is or what channel number it is, configure that number and press ENTER (save) button. Do the same with the remaining channels. Later I will tell you how to skip unwanted blank channels that usually have no signals but snow and lines, or have faint signals that can only be boosted with a TV booster available from reputable TV retailers, or install a bigger more powerful antenna.
Reagards.
Mike
Posted on Oct 06, 2009
How do you auto tune the Radio channels in or even do a search for different channels?
get the on screen menu up ( press menu on the remote) move around until you find auto tune , move sideways and it starts auto tuning
ti finds all radio and tv stations for you
when finished it may auto save or you will be required to press the ok button then exit
Mar 15, 2016 | Televison & Video
How to tune in beko tv with RC647340 remote
Hi ,
option one :
  1. Hold the "MENU" key down to access the TV Tuning menu.
  2. Once activated, the VOLUME +/-,
  3. PROGRAM +/- and
  4. STANDBY buttons are used.
option two
  1. on your remote control go to the menu button,
  2. go to settings,
  3. run auto tune.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Apr 03, 2011 | Beko 142746 TV
How do i get my toshiba regza lcd tv to work via the antenna/cable input
Change video source by pressing Input button and select TV, make sure antenna is connected in RF In jack in tv then go to Tuning menu and select Auto Tuning/ Auto Scan option, tv will tune and store all available channels in memory.
Let me know model number of tv if you have additional question.
Thanks.
Jan 08, 2011 | Toshiba Televison & Video
How can i autotune my soney trinitron tv iv lost the manual
Hello
Enter menu, and select the [autotune or auto search] function with the help of Prog+ Prog- and Vol+ and Vol- buttons. After that function highlighted press Vol+ button once and release. The TV will tune and store automatically in its memory, all the transmitting stations at that time, and after tuned the entire band it will finish tuning and will display the first channel. You must select auto tune for this. Not manual tune or fine tune functions. A horizontal bar will run across the bottom side of the screen indicating that the tuning process is in progress, and it will reset three times to zero and will continue tuning. It is due to the auto band selection is done inside the microcomputer of the tv. No other functions will response anymore, till autotune process is completed. Ok.
Oct 19, 2010 | Sony Televison & Video
How do you tune in a alba tv with no remote control
There is no way to tune it, the menus that you need to bring up can only be accessed with the menu buttons on the remote
Feb 28, 2010 | Televison & Video
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Retuned my Freeview receiver but now have black bars.
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Oct 01, 2009 | Sony BRAVIA KDL-40V4000E 40 in. LCD TV
Free view
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
Sep 19, 2008 | Sony 32 in. LCD TV
Sony KDL-20s2030
redo The retuning process is as follows:
May 20, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Nov 16, 2007 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
