Won,t download after last step - Computers & Internet
It keeps saying lens error
Here are some troubleshooting steps for the lens error problem. And here's a video summary of those steps:
Jan 13, 2013 | Canon PowerShot S3 IS Digital Camera
Tip
How to Hack a S60 phone?
Hacking an S60 phone(V5 and V3) is simple enough. Hacking is mainly done to avoid common problems that symbian users find wile installing cracked applications.<br /> I have listed it in a step by step way which you will find to your liking. <br /> Step 1. First download an application named xstevedore chinese. <a href="http://www.filestube.com/0aac7480d43108c903e9,g/XStevedore-chinese-signed.html">http://www.filestube.com/0aac7480d43108c903e9,g/XStevedore-chinese- signed.html</a> <br /> Step 2. Open up the application and browse to the last item on the screen. <br /> Step 3. It is "setting ". In this the options are : 1. Access point 2. Download path 3. Quit tips Just change access point which u want and i recommend u to change download path to memory card. <br /> Step 4. now go to the second last option Which is "signature ". Then go to options and u will find four options : Choose second one which is " certificate tool" . <br /> Step 5. after that again it will show two options.Choose second one which is "a button to download ". <br /> Step 6.Then downloading will start. <br /> Step 7. then it will ask to save.Then select memory card. <br /> Step 8. then browse to memory card.There u will find a folder named" my cert ". Ur certificates and key files are in the folder. <br /> Step 9 . After that you can use freeshiner or signsis to sign your files with your certificatesStep 4- now go to the second last option Which is "signature ". Then go to options and u will find four options : Choose second one which is " certificate tool" . <br /> Step 5. after that again it will show two options.Choose second one which is "a button to download ". <br /> Step 6. Then downloading will start. <br /> Step 7. then it will ask to save.Then select memory card. <br /> Step 8. then browse to memory card.There u will find a folder named" my cert ". Ur certificates and key files are in the folder. <br /> Step 9 . After that you can use freeshiner or signsis to sign your files with your certificates <br /> Signing softwares can be downloaded from www.mobile9.com
on Jun 29, 2011 | Cell Phones
My Sportline won't zero the steps
find your watch off this link below click on it and download the manual
http://www.sportline.com/products/heart-rate-monitors.html
Sep 20, 2012 | Watches
A friend gave me her HP psc 2210 AIO. She did not have the owner's manual. I have it hooked up. It turns on, but won't print. I need the operating instructions to get it going. I have a newsletter...
Hi Peggy,
Have you already installed the printer driver to your computer? This is one of the first things you should do when installing the printer aside from hooking it up to your PC. If you don't have the driver don't worry because you may download it by clicking on this link. Then follow the steps below:
1. Select your operating system (ex. Windows XP) then hit on Next.
2. Afterwards select Driver Product Installation Software.
3. Then hit on Download.
4. Once driver is downloaded, install it .
5. Lastly, restart your computer.
For your instruction manual download it from here.
Hope this helps.
Thank you for using FixYa.
Oct 23, 2011 | Office Equipment & Supplies
I forget my won password
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
hope this helps
Mar 18, 2011 | Computers & Internet
I have had this motherboard sitting in my PC doing nothing for quite some time. I finally decided to dust the PC off, and it will not boot. When I press the power button, the fans, HDDs and the CD drive...
The user manual will give you the jumper settings but I'm surprised you haven't tried the card you have as you consider it a video problem.
Manual here
http://support.asus.com/download/download.aspx?SLanguage=en-us
Apr 11, 2010 | ASUS P4P800-VM Motherboard
I have a lock symbol next to some of the icons in the setup menu and it won t let me select the. The unit it a Kenwood DNX-7100.
Pg. 82 in the manual:
Under Step Up > Set up Memory (last page of options) > Select Unlock.
I also had mine set up lock.
Apr 14, 2009 | Kenwood DNX7100 Car Video Player
My device turns on but shows message ¨refresh database¨ it won´t do anything else, what can do?
HI,
Try these steps:
  STEP 1 - Reset the device
1. Slide the Power switch up and hold it for approximately 20 seconds.
2. Release the Power switch once the device is powered down.
3. Turn the device back on.
STEP 2 - Download and Install the Sansa Firmware Updater
Jan 29, 2009 | SanDisk Sansa e260 MP3 Player
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
