Question about Cell Phones
I'm checking whether my application went successful or not
I'd like to know whether my application was successful or not.
we have no idea what you are asking about here at fixya
Jun 21, 2017 | Computers & Internet
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
Why i didn't get response on my application for nsfas 2017 whether my application was successfully or noy
NSFAS Contact Centre
If the general equires for students phone line cannot assist, perhaps the number related to accounts can. Note that there was a May 12th deadline for this particular tri-semester. Enquire whether yoeu made that deadline, whether your application is still active, and if your application is applicable for the next tri-semester. Perhaps other suggestions are available from this centre.
May 28, 2017 | Miscellaneous
How I will know if my application has been successfully or not successful
It will not open if the install failed, you will get an error message
Jan 19, 2017 | Computers & Internet
How do i apply at tut
  • Obtain a residence application form from Residence Administration and submit the form on or before 31 October.
  • Residence admission, depending on the availability of space, is only possible upon successful academic acceptance.
  • Successful applicants will be notified, via mail, between October to the end of November.
  • Late applications as well as students not accepted for a course yet, will be kept for enquiries as from January.
Indicate on your application form whether you need residence accommodation when you apply for admission to a course at TUT. A residence application form will be mailed to you when you are accepted for the course.
Forms can also be downloaded and be sent to Residence Administration once academical application was successful.
Jan 12, 2017 | Computers & Internet
Apple application support was not found
Apple Application Support can be downloaded at this link Apple Application Support 3 0
Feb 26, 2014 | Apple iTunes
Can't access my DVR remotely via Video Server E
why i cant remote access my dvr in WAn but LAN is working fine?
Jan 03, 2009 | 2wire 2700HG-B Router (2700HGB)
Blackberry pearl
the only thing that you can do for this error message is to reload the operating system on the blackberry. You have to have the blackberry desktop manager installed on your computer first. Once the program is installed then perform the following
To run Application Loader on your computer, follow these steps:
  1. Connect the handheld to the computer (insert the handheld in the cradle or connect directly by USB cable).
  2. Open the BlackBerry Desktop Manager.
    • Note: Click Start, Programs, BlackBerry, Desktop Manager.
  3. Verify that a pop-up window appears when the handheld is recognized.
  4. Click Application Loader if the pop-up window does not appear.
  5. Click Update Now.
    • Note: (This option only appears if new device software is available).
  6. Click Next to open the 'Handheld Application Selection' window.
    • Each application lists (along with its file size) with a check box and an 'Action' item.
  7. Review the following information about items that appear in the 'Action' column:
    • Install: Appears when an application is not present on the handheld.
      • The application loads on the handheld.
    • Update: Appears when the application version on the handheld is older than the version available with the Application Loader tool.
      • The most recent version of the application loads on the handheld.
    • None: Appears when the application version on the handheld is the same as the version available with the Application Loader tool.
      • The application does not change on the handheld.
    • Downgrade: Appears when the application version on the handheld is more recent than the version available with the Application Loader tool.
      • The older version of the application loads on the handheld.
    • Remove: Appears when a check box is cleared beside an application and that application was already present on the handheld.
      • The application is removed from the handheld.
    • Note: For more information on a particular application, select the application, then click Details. The handheld’s standard system software is also listed in the 'Handheld Application Selection' window. The software must be loaded on the handheld. The check box cannot be cleared.
  8. Click Next.< been have selections all>
    • The 'Application Data Backup' window appears.
  9. Verify that the first option is selected by default.
    • Note: This option automatically backs up handheld applications and data. Data restores after the handheld software reloads.
  10. Click Next.
  11. Click Finish when asummary window appears.
    • The actions that occur during the loading process appear.
  12. Verify that the handheld resets.
    • Note: This process may take a few minutes.
  13. Click Close to return to the Desktop Manager.
  14. Verify that the Application Loader indicates whether or not the process is successful.
    • Note: If the loading process is not successful, verify that the handheld is connected to computer properly. Repeat the above procedure if there was a connection error.
Oct 21, 2008 | RIM BlackBerry Pearl Smartphone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
