Master
- Posted on Aug 01, 2009
Re: How do you release the serpentine belt from the...
Here's how to get a serpentine belt on or off (You'll need to do both). It's easy and doesn't require a prybar.
On:
- Get a 14mm or 9/16" socket and a long handled ratchet or breaker bar.
- Get the belt around all the pulleys except the A/C compressor or Alternator.
- Locate the tensioner pulley. It's one of the smaller
ones and is mounted on a spring loaded arm. It's job, as the name
suggests, is to keep the belt tight. Get your socket on
the center nut of this pulley.
- Slowly pull the ratchet toward the center of the
engine. The pulley will pivot on the arm allowing you to get the belt
on the final pulley.
- Slowly release the tension.
- You're done
Off:
off one of the pulley's (A/C or Alternator is best)
- You're done
Mike
