Question about Cell Phones
Why my magic jack is not working? - Cell Phones
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
Magic jack customer service
Well, you'd best go to Magic Jack's web site, and either log in to your sister's account and cancel it, or try to find a Magic Jack customer support telephone number and make the call.
Aug 22, 2014 | Computers & Internet
We renewed magic jack account phone not working
You need to contact magic jack. Sorry, we can't help with that issue.
Mar 23, 2014 | Computers & Internet
Old majic jack want to start new program
If you have an old Magic Jack, my 4 unit are 6 years old the company just really wants you to upgrade to a newer product no need to. Try removing Magic Jack completely from your tablet, restart unit, make sure to clean out all junk on tablet from Magic Jack you could try a program that cleans your tablet for you, but unless you know what to remove don't get technical just a standard clean up of old files, this is usually under apps, Magic Jack, then there will be a clear cash button, clear data, and uninstall.
Restart unit then do a fresh install of Magic Jacks new app for your type of tablet from Googles sight or Magic Jacks make sure if you have a Mac to install the Mac App and if you have an android tablet you install the Android App. This has been working for me. With the old Magic Jack you will need to do a fresh install when you get errors and crashes. I do it 2 or 3 times a year. Good Luck!!
Jan 06, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
Fax magicjack
  1. Operating Systems
    • As of 2010, the Magic Jack works well with Windows XP and Vista machines. Windows 7 has reported problems listed on their Microsoft Answers forum.
    Do Not Support
    • According to the Magic Jack company website they "...do not officially support using faxing with Magic Jack."
    Testing the Fax
    • Test your fax machine with Magic Jack by turning off the error correction on the machine and using the slowest speed available. If successful at that speed, increase the speed and check if it continues to work.
Read more: Does Magic Jack Support Faxing? ' eHow.com http://www.ehow.com/facts_7148239_magic-jack-support-faxing_.html#ixzz1tntAK093
May 02, 2012 | magicjack.com
Magic jack: computer virus took out our computer and now back in action. People can hear me, but I can't hear people on magic jack. help
Hello.
Your router may be blocking outgoing connections from the magic jack. Magic jack works on the following ports UDP 5061, TCP 80 and TCP 443. Look at the documentation on your firewall to open the ports to allow outgoing connections on these ports.
Hope this helps.
Aug 12, 2010 | Lands Phones
FAX MACHINE WILL NOT WORK WITH MAGIC JACK
Magic Jack will work with fax machines. You may have to experiment by slowing down the fax machines modem transmits speed. This is done in the machines menu.
The Magic Jack manual is quite clear, it can handle faxing.
Mar 21, 2010 | HP 640 Inkjet Fax Machine
Brother mfc-240c cannot send fax using magic jack. Any solution?
I had the same problem with my Brother Mfc-240C.
I had the line connected to the dual jack.
6f90994.jpg So I changed out the Dual Jack., and worked fine.
If you are still having problems, then don't use the dual jack. Just connect it straight into the Magic Jack. Here is a link for setting up magic jackl.
http://text.broadbandreports.com/forum/r18763226-Magic-Jack-Setup-Pictures
If you find this helpful, pls rate me.
Thanks and Good Luck.
Jan 27, 2010 | Brother Multi-Function Center MFC-240C...
I have magic jack and am trying to use it for a medical device because I have a pacemaker and defibulater and it need to be monertered by a LATITUDE COMMUNICATOR.Can magic jack be used for the LATITUDE...
I have and use Magic Jack too..Does your Latitude Communicator just plug right into a phone jack with a regular phone cord? If it does, then it should work...You will have to always leave your laptop on and never turn it off because Magic Jack requires a constant connection...Plug your equipment into the back of your Magic Jack and then with another phone, call the company that monitors your pacemaker/defibulator and ask them to "test" your line to see if you will receive a signal from them through your Magic Jack...You will to have to plug it all in and then test or you won't ever know...When I plug my home phone into the back of my Magic Jack, I receive a dial tone just like it was connected to a home based landline phone
Jul 16, 2009 | Acer Computers & Internet
Need to find fax machine thats compatable with magic jack
Magic Jack is digital, fax machines are analog....it won't work.
Mar 02, 2009 | Panasonic KX-FHD331 Plain Paper Thermal...
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
