Question about Home
Leak appears to come from toilet mount area - Home
  • Phil Herold
    Phil Herold Feb 13, 2017
    Hi please. Be more specific
    The are two seal on the toilet pan
    First is called a mulitfit (unles its very old) and fixed into a cast iron waste pipe if that the case you need to dig out the now very hard putty and replace it
    If it's a more recent then the multi quick fit has failed
    Needs to replaced
    Turn off the water suppy, dissconect the flush pipe
    Unscrew the pan, remove the existing muilti quick seal
    And replace it (note add a little washing up luiqid it will the slide straight in
    While the pan is out replace the flush pipe rubber seal (push fit)
    Also make sure the big plastic nut under the syctern
    Is screwed titely (if thats ware the leak is)
    Turn off the water supply, empty thecistern by pumping the handle flush, ( you get it all out) use a sponge for the last "3" inches of water , when empty
    Unscrew the big nut under neath on the flush pipe
    Remove the sifon, replace the thick s
  • Phil Herold
    seal, refit the syphone unit. Run a little PTFE tape around the thread make sure the pipe is sqware in the union screw up the big nut( do not over tighten
    Job done
    Problem Solver:
  • 15 Answers
Wesley, if you are talking about where the toilet mounts to the floor then you will have to remove the toilet and replace the toilet flange seal. There are several different types of seals and I would recommend the non-wax type. If you are talking about where the tank mounts to the toilet base there are several places where the leak could be coming from. You can buy a repair kit at most any hardware or home improvement store. There are also a variety of helpful videos on YouTube that can walk you through the process if you've never done this before. Good luck!
    Top Expert:
  • Home Master
  • 45,079 Answers
Defective bowl seal
Loose toilet
Get a package of toilet shims from a hardware store. Look at the bolts on both sides of the commode that mount to the floor. There may be covered with a cap. Slide shims under the ceramic until the rocking stops. Carefully tighten the bolts until the unit is solid.
If the flange bolts are no good, you can change them (again the hardware store), but you will have to remove the commode and replace the wax ring before resetting it.
Apr 07, 2015 | Home
I have a 2013 Thor freedom elite 28z
if leaking from directly from behind toilet, check connection also if leaking from back of toilet. more than likely it is the vacuum valve on back of toilet. $50 dollar part. if not leaking there. pull all drawers in bathroom out. they lift out. if the inlet for the pressurized water is there, it is probably leaking from the inside. it is a $15 part but depending on access, does is leak when hooked up to water from pressure side or does it leak with just 12 volt water system?
Jun 10, 2014 | Thor Motor Coach 2013 Challenger 36FD
Toilte leaks in front have chk the lines and find no leaks. Is it the toilte
If you have found no leaks on the supply line, be sure to check the seal between the tank and the bowl. This is a common source of leaks, especially on older toilets that have seen much use.
Before you do that though, check carefully at the base of toilet to see if its possible any water is appearing from under the toilet. Your toilet sits on a seal, most often made of wax (sometimes rubber) that seals the water and waste from the toilet into the drain pipe. Normally, those seals last many years. Flush the toilet 3-4 times and observe whether any water seeps out under the toilet. Give it a few minutes (4-5) and recheck. If it is leaking, the fix is pretty simple: Shut off the water, disconnect the source water line just so you won't risk breaking it, and remove the 2-4 toilet bolts. Rock the toilet gently and pull straight up until the seal comes loose. The beeswax seals seem to work the best. Scape off as much of the old wax as you can, and set a new one. They are very inexpensive, and sell for around $2-3.00 USD. To reinstall, remove the protective lining (if present) on the wax, place the ring on the toilet, not the flange and carefully place it straight down onto the flange. Try not to make a mistake - line it up carefully. Press down on the toilet's seat area, maybe rocking yourself a little, until you can see the toilet is back in position.
Next, VERY CAREFULLY tighten the toilet's mounting bolts, a bit at a time, until secure. Over-tightening can break porcelain toilets, so be careful.
OK - either that's fixed or you've ruled it out. Next is the tank seal. Unfortunately, the only way to get to it is take the tank off. If its come to that, first go to the hardware store and secure a replacement set containing the tank seal, a new pair of brass bolts, and the bolt seals. Expect to pay around $4-5.00 USD for the set. The job is pretty easy, you use a wide flat-bladed screwdriver to loosen the (usually) brass screws in the bottom of the tank after shutting off the water and while an assistant holds the nuts from the bottom. You COULD do if yourself, but an assistant makes it easier. Carefully lift off the tank, and you'll see the seal. Remove it, and replace it with the new one, being careful to put it in the right direction, as they are usually cone-shaped. Set the tank back on, put the screws back in, using new seals/bolts (just for good luck) and reassemble. BE CAREFUL when tightening the bolts!! You can easily crack the tank if overtightened.
This is a lot of writing, but just to give you an idea, I could probably change a wax ring in 10 minutes, and the tank seal in 15 or so. Best wishes -
Jun 09, 2014 | Electronics - Others
I have a problem with the water in the tank leaks past something, maybe the flush valve assembly and the tank has to refill about every 25 min. I got a new flush valve assembly and changed it and put...
Hi keithn60...
I had the same problem one time with my toilet tank, the answer is to put some silicone on the seal washer between the take and bowl assembly and to use a level on the tank to tighten it just enough to be level and not leak.
Please take time to rate me
Jun 27, 2011 | American Standard 4021 White Cadet 3...
Toilet tank cracked
You can find a replacement tank on the manufactures website. However, if it's not leaking or leaking very little you can cover the crack, on the inside of the tank, with an epoxy compound. There is a whole lot of pressure on the inside of a tank and typically when they crack it shows up as a very slow leak as the water seeps through the crack. When using the epoxy don't try to put it just in or on the crack. Seal an area a couple inches either side of the crack. These are usually hair line cracks and you won't necessarily be able to see the entire area of damage.
Oct 04, 2010 | Crane Plumbing 3755 Toilet-To-Go Metro...
The toilet seems to be leaking from the bottom. The seal was replaced before and it seems to be leaking when the toilet is not in use. There isn't any leaks from any of the connections that are visible...
When you have a leak at the bottom there are only a couple of options. One, the seal that was replaced wasn't done properly and needs to be replaced. If you didn't have to sit on it to squash it into place the seal was to thin and you need an oversized wax seal. The other option which is very rare is that the tank itself has a crack and is leaking from the bowl. Like I said, this is very rare. One easily overlooked area is where the tank and bowl are connected. There is a seal between the two and can also leak. This leak will be slow and will usually run down the side of the bowl where you can't see it until it ends up on the floor. If you do find this to be the problem, replace that seal and be sure you don't overtighten the mounting bolts.
My suggestion is that you do both at the same time. As long as you have the water shut off and the tank drained, do them both and alleviate all the problems at one time. The extra cost for the seal between the tanks is only a few dollars.
Oct 02, 2010 | Kohler Home
Kohler welworth enlongated 2 piece toilet with class 5 flush. I can hear the water running intermittently - tank does not appear to be leaking into the bowl or otherwise. Otherwise, the toilet appears to...
Place a few drops of food coloring in the tank of the toilet, if it is leaking you will see the color seep into the toilet bowl within a short period of time. If you see the food color in the toilet bowl you will need to replace the flapper.
Oct 28, 2009 | Kohler Home
Kohler one-piece lowboy..rialto? leaks from suply below tank
I'm assuming based on your post that the leak is outside the toilet near the inlet to the fill valve. Based on 10 years in the business, there shouldn't be holes in or near this place. Have you tried replacing the fill valve? If you go to the hardware store and look at a new fill valve, you will find that there aren't any holes. They aren't expensive, so I would just replace it.
Apr 11, 2009 | Kohler 3386-6 Rialto Skylight Round Front...
Home Logo
2,769 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
