Question about Samsung Audio Players & Recorders
Samsung electro \motherboard wiring diagram\FCC ID : E2XHK359\3-PIECE SYSTEMWITH SUBWOOFER AND SATELLITE\MODEF: HK395
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 7 Answers
SOURCE: Can I use this subwoofer for a home theater system
yes you could but you would need to soder and take the stuff apart
Posted on Jul 05, 2009
drifterK
  • 4924 Answers
SOURCE: ihave hk395 subwoofer..but i dont have the satellite and a two speakers..it is possible to use it...if not were i can buy..
U can use the sub-woofer by plugging it separately with a normal 2 stereo speakers.. or ..use 2 speakers attached on it ..be sure they are powerfull enough to make a match ..(usually it is enough 10 watt )
to plug t separately ..just take a look in the speaker configuration option of the driver..and change it in such a way that will allow you multiple out ..(you will see which one will be what ...even on a normal sound card with only 3 plugs ..The configuration you have to choose is probably 3=1 or so ...and will leave your pink for a microphone ..and the line in will turn in a out-let for the woofer ..
Or if the woofer have inlets for the speakers and has a amplifier built in ..you can attach any speakers..
In this case you can use teh normal speaker out ..and get the signal for the other speakers from the woofer ..
In case they were separate ..and the woofer was only connected with the central ..use like I say ..a configuration on the sound manager (speaker configuration ) in such a way that you will be able to connect the speakers in normal green out and use regular 2 stereo ones..and attach the sub-woofer in the plug specified in the diagram ..usually for 3=1 or 4=1 it will change the blue line in into woofer out ..and will work
In this case the speakers used in the green out have to be amplified separately (or have a built in amplifier like computer speakers have ).please ask if you didn't understood the procedure ..and please rate my answer
Posted on Dec 28, 2011
  • 64 Answers
SOURCE: HK395 SUBWOOFER PINOUT DIAGRAM
Posted on Aug 07, 2012
  • 64 Answers
SOURCE: HK395 Speakers/Subwoofer Cable
How to use hk395 subwoofer without satellite speakers
System power is controlled by a switch on the right satellite speaker ON/OFF VOLUME control, therefore you would have to connect a separate switch to control power. However, you may be able to get a satisfactory result by turning the satellite volume control completely counter clockwise and adjusting the WOOFER VOLUME control to the desired level.
Jan 21, 2015 | Audio Players & Recorders
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
Del harmon kardon hk395 9 pin plug
Harman Kardon HK 395....I posted here how to use the subwoofer if you don't have the original satellite speakers. http://audio.manualsonline.com/ex/thread/view/idThread/1732002
Sep 14, 2009 | Dell HK395 Computer Speakers
Won't power up
  • Make sure all connections on the rear of Subwoofer are properly inserted in their connectors.
  • Check to see if LED illuminates on the front of right satellite speaker. If it is not illuminated, check the power connections.
  • Make sure power switch on satellite is turned on.
~gnomer
Jan 04, 2009 | Dell Dimension 4600 PC Desktop
Jan 04, 2009 | Dell HK395 Computer Speakers
Jul 26, 2007 | Dell HK395 Computer Speakers
How do i fix my sub woofer?
U just remove subwoofer and clean it with a piece of cloth, then fix it ur computer it will wirk. If not, pls make service it.
Nov 02, 2006 | Dell HK395 Computer Speakers
52 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
