Question about Home
Little black flecks are coming from the jets along with tub water. Why? What can I do about it?
SOURCE: Aquglass jet tub will only humm no bubbles out of none of the jet
When a motor hums, it usually is the result of what is called "locked rotor." This can occur when the motor's brushes remain on one pair of the commutator contacts. The magnetic field does not shift to the next set of windings and the rotor is locked in place by the unchanging magnetic field.
If you have access to the motor, turn on the power briefly and place your hand gently on the side of the motor. Probably you will feel the vibration of the hum you are hearing, together with some heat. In locked-rotor condition, the motor draws high amperage and heats up quickly. Turn off the power.
If this is the condition, the motor is shot and needs to be replaced. You should copy down the information from the name plate (model and serial number, manufacturer, horsepower, amperage, etc.) and contact the manufacturer or a local appliance parts store about a replacement.
As you said that you recently bought the house, you may have a home-owners warranty which may cover the appliance.
Posted on Jan 10, 2009
  • 272 Answers
SOURCE: Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
Posted on May 25, 2009
  • 62 Answers
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Posted on Jul 11, 2009
  • 80 Answers
SOURCE: Leaks from jets along outer wall
This is a hard fix, The jets are glued on to the back of the tub with an epoxy type material. the jets should spin on and off from the inside of the tub. You need to determine if it is the hole where the jet is that's leaking or if it is the jet assembly and tubing that is leaking. If it is the jet hole that is leaking, spin the jet off and use aquarium grade silicone (Lowes carries it)
spread this around the piece sticking thru the tub and spin the jet back on. This is a hit or miss fix. No easy fix if it is the tubes or jet assembly, full access necessary for this repair.
Posted on Aug 19, 2009
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Posted on Nov 24, 2010
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 | Jet Home
How do I get bad smell and crud out of jacuzzi jets
If you are experiencing a "smell" coming out of the water when you use the tub then you should use one of the products that are made for cleaning jetted tubs pipes.
Here is a link to a site that carries those items. These will get rid of the nasty smell and flecks of bacteria when you use the tub too.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Rod
US Parts Center
Mar 15, 2014 | Home
Air jet tub shoots out black flakes
it sounds like there is a build-up of some kind in the lines. Replacing the lines may be your simplest solution. Replacing the entire system would definitely fix the black flakes.
Dec 27, 2013 | Home
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Jets in the tub has mold what product to use
There are many solutions for this problem in whirlpool Bathtubs.
There are a few products out there that will clean your tub up and used on a regular basis will keep it from getting those black little flecks from coming around.
This store has quite a few options for you to look at.
Tub Maintenance
click on that link and check them out if you would like to.
Rod
US Parts Center
888-521-6183
Jan 14, 2013 | Home
Lasko pump motor in jetted tub comes on when switch is turned on but doesn't pump any water from jets. Unit has been used very little and is about 8 years old. Is there any such thing as priming these...
you can check to make sure there is water to the front of the pump. What they use on their tubs is called flooded suction pump i.e. there has to be enough water to the front of the pump end to **** it through and push it up and out of the wet end.
fill your tub up and loosen the discharge union on the top of the pump until water starts to come out, quickly tighten the union back down and then see if you can get the pump to start pushing water.
Dec 31, 2010 | Jacuzzi 8450-959 Tara Whirlpool Bath 5'-...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
May 25, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Apr 24, 2009 | Home
Black soot in my jacuzzi tub
sounds like the rubber seals are going bad, does it recomend to run cascade thru the jets? this might be harmful to the gaskets and the pump, you maight want to disconnect the hose and flush out the tubes going around the tub, but I would call jacuzzi and ask them if this is good to run thru there, thye might be able to help you with the gaskets, questions over the phone do not cost you, call them, ask for repairs section good luck
Feb 27, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Home Logo
81 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
