Question about Health & Beauty
Tensoval blood pressure machine keep showing error 3
Max J
  • 22 Answers
SOURCE: Blood pressure reading 150/76. Manual Blood pressure 130/72
A monitor using Hg is only a valid monitor reading. Most electronic devices produce approximate results and are mostly good for taking several readings daily and obtaining a mean daily BP. Device calibration appears to be not accessible to the the user.Also, depending on age & condition of your dad, sequential reading must take place after elapse of enough time for circulation to be at steady state in the arm again, or if you immediately after a measurement make another, even with the same monitor you will obtain a different result.
Posted on Sep 07, 2009
Max J
  • 22 Answers
SOURCE: WITH AUTOMATIC CUFF BLOOD PRESSURE MONITOR GETTING ERROR
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
SOURCE: How to clear memory on a ReliaMed wrist blood preassure machine
  • Make sure the unit is off
  • Hold down on the memory button until you see "CL" (clear)
  • Once you see CL appear on the screen release the memory button then tap memory once
  • You will hear a series of beeps
  • Memory is now cleared
  • Posted on May 14, 2010
    SOURCE: what does error 3 on my microlife blood pressure
    I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
    Posted on Dec 04, 2010
    SOURCE: Walgreens HD303 Blood Pressure Monitor error 3
    Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..
    Error Description Potential cause and remedy
    «Err 3» No pressure in the cuff
    An adequate pressure cannot be generated in the cuff. A leak
    may have occurred. Replace the batteries if necessary. Repeat the
    measurement.
    Error Codes
    Err 0 No pulse is detected
    Err 1 Inflation rate is too low
    Err 2 Systolic reading unattainable
    Err 3 Cuff pressure is too high
    Err 4 Diastolic pressure is outside of operation range
    Err 5 Cuff deflated too fast
    Err 6 Cuff deflated too slow
    Err 7 Systolic pressure is outside of operation range
    Err 8 Overall pressure is outside of operation range
    Err 9 Cuff is unable to inflate to the necessary pressure level
    Error No. Possible cause(s)
    Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
    Err 2 The arm was moved during the measurement.
    Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
    Posted on Jan 19, 2011
    What does error 3 on my microlife blood pressure monitor
    Repeat measurement keeping arm still. If inflation of the cuff takes too long, the cuff is not correctly seated or the hose connection's not tight. Check connections and repeat
    Jan 10, 2015 | Microlife Health & Beauty
    My blood pressure machine keeps giving me an error 3 it is a cvs brand
    Several of the CVS brand blood pressure monitors are made by MicroLife USA. For those models, the Error 3 indicates that you may have been moving your arm while the unit was obtaining the readings. You need to repeat the measurement while staying still.
    The other possible cause of the error are that the cuff didn't inflate in a reasonable length of time. Check that the cuff is properly placed on your arm. Also make sure that the inflation hose is tightly connected to the cuff socket on the unit.
    I hope this helps.
    Aug 14, 2014 | Health & Beauty
    Error 3 is showing on my monitor ... What does it mean ?
    On other blood pressure monitors from Life Source, the error 3 means that the blood pressure cuff isn't inflating properly. The cuff could be incorrectly fastened or the air connector is backwards or not connected to the cuff or the monitor. Check this on your monitor.
    I hope this helps.
    Jul 08, 2014 | Health & Beauty
    I get error codes on the unit. Can you tell me what the error codes mean?
    I AM GETTING ERROR 3 ON MY LIFESOURCE BLOOD PRESSURE MOINTOR 7 WHILEPUSHING ON START BUTTON,IT DOES NOT GO AHEAD MORE THEN FIGURE 2 & COMES BACK TO 1 & THEN SHOWS ERROR 3,CAN ANYONE,SUGGEST OR GIVE SOLUTION/REMEDY ON MY MAIL ID:hemant_pandya12@yahoo.com I HAD LOST OPERATING MANNUAL & WARRANTY CARD,ALTHOUGH THIS MONITORING INSTRUMENT'S HAVING LIFE TIME WARRANTY,INCLUDING CUFF. THANKING YOU.
    H.M.PANDYA.
    Mar 03, 2011 | Lifesource Digital Blood Pressure Monitor...
    Blood pressure cure keep reading error and it is never charge even keep the machine charging overnite
    Make sure that the cuf is over your artery, there will be a little plastic point in the cuff to show you where it goes, which is right in the fold of the upper arm from the elbow..... Take care.... Guy
    Sep 06, 2010 | Walgreens By Homedics Automatic Blood...
    I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
    Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
    Feb 09, 2010 | Health & Beauty
    Err 3 is displayed
    Wrist blood pressure monitors must be used with the arm above heart level. You can do the pledge of allegiance while doing a reading to make sure this is done. Usually this error occurs when inflation takes too long or the placement of cuff is wrong.
    Sep 10, 2009 | Walgreens Wrist Blood Pressure Monitor
    Mar 04, 2009 | Mabis Automatic Digital Blood Pressure...
    Health & Beauty Logo
    56 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
