Question about Kenmore Microwave Ovens
Hi my kenmore oven dosen't hit up the model number is C970648227do you have any advise?
How do I turn off the sound on my new Kenmore Elite microwave?
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
Dec 11, 2014 | Kenmore EM262A5E Elite Stainless Steel...
My still fairly new kenmore 1000 watt microwave appears to be operating fine but doesnt heat. What might be the problem?
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Post a new help request with the answers to these questions as well as the full model number from the tag on or in the unit.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Apr 14, 2013 | Kenmore 62622 Microwave Oven
Kenmore microwave oven model 721
On the link below is the list of Kenmore microwave oven model manuals starting with 721.Click on selection to download.
www.managemylife.com/mmh/owner_manuals/search?query=Kenmore+micicrowave%2Fhood+combo+-+7218924680
Hope this helps.Thanks!
Jan 07, 2012 | Microwave Ovens
Kenmore microwave model 665.62612201 set time hit start control board counts down unit does not come on
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;
Apr 16, 2011 | Microwave Ovens
Kenmore model number 721.80593400 everything works but will not heat food it also sounds louder. I just replaced the magnetron and that did not help any ideas.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | Kenmore 80012 Microwave Oven
ASKING FOR TIME OF DAY BUT WHEN I PUT IT IN IT WILL NOT DO ANYTHING WHEN I HIT THE START BUTTON. THIS MODEL DOES NOT HAVE A RESET BUTTON.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a bad keypad.
Jot down your full model number and see here for more help.
Aug 22, 2010 | Kenmore 80012 Microwave Oven
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
Kenmore microwave
If this has a controller that runs a microwave and an oven, then the problem F2 means a temperature related fault such as a bad temp sensor / thermostat or a defect in the control board. If it's just a microwave, then the problem is likely a failing keypad. In many cases, those can be replaced economically. If you repost with your exact model number (62622 is not a complete model number) then we can advise you further and more specifically.
Nov 22, 2006 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
24 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Jim Thurston
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
